Replace api_streams by installing websockete_api won't work
HI,
Since api_streams are deprecated, following the documentation on websocket_api, I’ve tried adding the
websocket_api:
to configuration.yaml and
  - platform: websocket_api
but checking the config errors in the sensor platform not being found.
05
Do we need to set anything besides the above entries? Hassio 84.3 here
is the websocket_api a new feature in the latest release(s) or has it been there for a while?
I see you are on v84. It might not be available for you unless you update.
not sure, I only tried because api_streams will be deprecated with the next update.
I checked the docs and it say websocket_api is Introduced in release: 0.34.
