Replace point to comma in ESPHome on ST7798v 320x240 display
I’m struggling for days to try to replace point to comma on my display. I get a value as British and American English notation 1.0734 and want to have the European notation with a comma 1,0734.
I would appreciate some help to solve this issue because this is driving me mad :sweat_smile:.
My code:
  platform: esp32
  board: esp32-c3-devkitm-1
  on_boot:
    priority: 200
    then:
      - light.turn_on:
          brightness: 75%
# Enable logging
logger:
  logs:
    component: ERROR
# Enable Home Assistant API
api:
  encryption:
    key: "xxxxxxxxxxxxxx"
ota:
  password: "xxxxxxxxxxxxxx"
wifi:
  ssid: !secret wifi_ssid
  fast_connect: true
  manual_ip:
    static_ip: 192.168.178.44
    gateway: 192.168.178.1
    subnet: 255.255.255.0
  ap:
    ssid: "Esp32-Mini-Display"
captive_portal:
# Display ST7789V 320 x 240
# Vcc 3V3
# GND GND
# SCL GPIO9
# SDA GPIO6
# RES GPIO5
# DC  GPIO3
# CS  GPIO4
# BLK GPIO7
status_led:
  pin:
    number: GPIO8
    inverted: true
  - platform: wifi_signal
    name: "WiFi ESP32 Mini Display"
    update_interval: 60s
  - platform: internal_temperature
    name: "ESP32 Mini Display Temperature"
    unit_of_measurement: °C
    accuracy_decimals: 0
  - platform: homeassistant
    entity_id: sensor.system_monitor_processor_use
    internal: true
    entity_id: sensor.home_assistant_core_memory_percent
    internal: true
    entity_id: sensor.system_monitor_disk_usage_percent
    internal: true
    entity_id: sensor.system_monitor_processortemperatuur
    internal: true
    entity_id: sensor.lan_temperature
    internal: true
    entity_id: sensor.speedtest_download
    internal: true
    entity_id: sensor.speedtest_upload
    internal: True
    entity_id: sensor.speedtest_ping
    internal: true
    entity_id: sensor.euro_price
    internal: true
    entity_id: sensor.euro_change_24h
    internal: true
time:
output:
  - platform: ledc
    pin: GPIO7
light:
  - platform: monochromatic
    output: GPIO7
    name: "Display Backlight"
binary_sensor:
    entity_id: switch.lan_door_switch
    internal: true
    entity_id: switch.rpi_cooling_fan
    internal: true
font:
  - file: 'DejaVuSans-Bold.ttf'
    extras:
      - file: "DejaVuSans-Bold.ttf"
        glyphs: [$,€]
color: # RGB
  - id: white
    hex: '808080'
  - id: orange
    hex: ff8c00
  - id: red
    hex: cc0000
  - id: dark_blue
    hex: '000033'
  - id: blue
    hex: 0066cc
  - id: green
    hex: '009900'
spi:
  clk_pin: GPIO9
  mosi_pin: GPIO6
display:
  - platform: st7789v
    model: Custom
    width: 240
    height: 320
    offset_height: 0
    offset_width: 0
    rotation: 0
    eightbitcolor: true
    cs_pin: GPIO4
    dc_pin: GPIO3
    reset_pin: GPIO5
    pages:
    - id: page01
      lambda: |-
        it.printf(0, 10, id(font1), white, TextAlign::BASELINE_LEFT, "SSD Drive");
        if ((id(ha_disk).state) > 0 and (id(ha_disk).state) <= 60) {
          it.printf(240, 10, id(font1), white, TextAlign::BASELINE_RIGHT, "%.0f %%", id(ha_disk).state);
        if ((id(ha_disk).state) > 60 and (id(ha_disk).state) <= 80) {
          it.printf(240, 10, id(font1), orange, TextAlign::BASELINE_RIGHT, "%.0f %%", id(ha_disk).state);
        if ((id(ha_disk).state) >80 ) {
          it.printf(240, 10, id(font1), red, TextAlign::BASELINE_RIGHT, "%.0f %%", id(ha_disk).state);
        it.printf(0, 25, id(font1), white, TextAlign::BASELINE_LEFT, "CPU Usage");
        if ((id(ha_processor).state) >= 0 and (id(ha_processor).state) < 10) {
          it.printf(240, 25, id(font1), white, TextAlign::BASELINE_RIGHT, "%.0f %%", id(ha_processor).state);
        if ((id(ha_processor).state) >= 10 and (id(ha_processor).state) <= 50) {
        if ((id(ha_processor).state) > 50 and (id(ha_processor).state) <= 75) {
          it.printf(240, 25, id(font1), orange, TextAlign::BASELINE_RIGHT, "%.0f %%", id(ha_processor).state);
        if ((id(ha_processor).state) > 72 ) {
          it.printf(240, 25, id(font1), red, TextAlign::BASELINE_RIGHT, "%.0f %%", id(ha_processor).state);
        it.printf(0, 40, id(font1), white, TextAlign::BASELINE_LEFT, "Memory Usage");
        if ((id(ha_memory).state) >= 0 and (id(ha_memory).state) < 10) {
          it.printf(240, 40, id(font1), white, TextAlign::BASELINE_RIGHT, "%.0f %%", id(ha_memory).state);
        if ((id(ha_memory).state) >= 10 and (id(ha_memory).state) <= 50) {
        if ((id(ha_memory).state) > 50 and (id(ha_memory).state) <= 75) {
          it.printf(240, 40, id(font1), orange, TextAlign::BASELINE_RIGHT, "%.0f %%", id(ha_memory).state);
        if ((id(ha_memory).state) > 72 ) {
          it.printf(240, 40, id(font1), red, TextAlign::BASELINE_RIGHT, "%.0f %%", id(ha_memory).state);
        it.printf(0, 55, id(font1), white, TextAlign::BASELINE_LEFT, "CPU Temperature");
        if ((id(cpu_temperature).state) > 0 and (id(cpu_temperature).state) <= 60) {
          it.printf(240, 55, id(font1), white, TextAlign::BASELINE_RIGHT, "%.0f °C", id(cpu_temperature).state);
        if ((id(cpu_temperature).state) > 60 and (id(cpu_temperature).state) <= 65) {
          it.printf(240, 55, id(font1), orange, TextAlign::BASELINE_RIGHT, "%.0f °C", id(cpu_temperature).state);
        if ((id(cpu_temperature).state) > 65 ) {
          it.printf(240, 55, id(font1), red, TextAlign::BASELINE_RIGHT, "%.0f °C", id(cpu_temperature).state);
        it.printf(0, 70, id(font1), white, TextAlign::BASELINE_LEFT, "LAN Temperature");
        if ((id(lan_temperature).state) > 0 and (id(lan_temperature).state) <= 32.5) {
          it.printf(240, 70, id(font1), white, TextAlign::BASELINE_RIGHT, "%.0f °C", id(lan_temperature).state);
        if ((id(lan_temperature).state) > 32.5 and (id(lan_temperature).state) <= 35) {
          it.printf(240, 70, id(font1), orange, TextAlign::BASELINE_RIGHT, "%.0f °C", id(lan_temperature).state);
        if ((id(lan_temperature).state) > 35 ) {
          it.printf(240, 70, id(font1), red, TextAlign::BASELINE_RIGHT, "%.0f °C", id(lan_temperature).state);
        it.printf(0, 100, id(font1), white, TextAlign::BASELINE_LEFT, "RPi FAN");
        if (id(rpi_fan).state) {
          it.printf(240, 100, id(font1), blue, TextAlign::BASELINE_RIGHT, "ON", id(rpi_fan).state);
        } else {
          it.printf(240, 100, id(font1), white, TextAlign::BASELINE_RIGHT, "Off", id(rpi_fan).state);
        it.printf(0, 115, id(font1), white, TextAlign::BASELINE_LEFT, "LAN Door");
        if (id(lan_door).state) {
          it.printf(240, 115, id(font1), blue, TextAlign::BASELINE_RIGHT, "OPEN", id(lan_door).state);
        } else {
          it.printf(240, 115, id(font1), white, TextAlign::BASELINE_RIGHT, "Closed", id(lan_door).state);
        it.printf(0, 145, id(font1), white, TextAlign::BASELINE_LEFT, "Download Speed");
        if ((id(i_download).state) >= 100 ) {
          it.printf(240, 145, id(font1), white, TextAlign::BASELINE_RIGHT, "%.0f Mbps", id(i_download).state);
        if ((id(i_download).state) < 100 and (id(i_download).state) >= 80) {
          it.printf(240, 145, id(font1), orange, TextAlign::BASELINE_RIGHT, "%.0f Mbps", id(i_download).state);
        if ((id(i_download).state) < 80 ) {
          it.printf(240, 145, id(font1), red, TextAlign::BASELINE_RIGHT, "%.0f Mbps", id(i_download).state);
        it.printf(0, 160, id(font1), white, TextAlign::BASELINE_LEFT, "Upload Speed");
        if ((id(i_upload).state) >= 100 ) {
          it.printf(240, 160, id(font1), white, TextAlign::BASELINE_RIGHT, "%.0f Mbps", id(i_upload).state);
        if ((id(i_upload).state) <= 100 and (id(i_upload).state) >= 80) {
          it.printf(240, 160, id(font1), orange, TextAlign::BASELINE_RIGHT, "%.0f Mbps", id(i_upload).state);
        if ((id(i_upload).state) < 80 ) {
          it.printf(240, 160, id(font1), red, TextAlign::BASELINE_RIGHT, "%.0f Mbps", id(i_upload).state);
        it.printf(0, 175, id(font1), white, TextAlign::BASELINE_LEFT, "Ping Time");
        if ((id(i_ping).state) > 0 and (id(i_ping).state) <= 30 ) {
          it.printf(240, 175, id(font1), white, TextAlign::BASELINE_RIGHT, "%.0f ms", id(i_ping).state);
        if ((id(i_ping).state) > 30 and (id(i_ping).state) <= 60) {
          it.printf(240, 175, id(font1), orange, TextAlign::BASELINE_RIGHT, "%.0f ms", id(i_ping).state);
        if ((id(i_ping).state) > 60 ) {
          it.printf(240, 175, id(font1), red, TextAlign::BASELINE_RIGHT, "%.0f ms", id(i_ping).state);
        it.printf(0, 205, id(font1), white, TextAlign::BASELINE_LEFT, "EUR/USD");
        it.printf(100, 205, id(font1), white, TextAlign::BASELINE_LEFT, "%$ %.4f", id(euro_price).state);
        if ((id(euro_change).state) >= 0 ) {
          it.printf(240, 205, id(font1), green, TextAlign::BASELINE_RIGHT, "%.1f %%", id(euro_change).state);
        } else {
          it.printf(240, 205, id(font1), red, TextAlign::BASELINE_RIGHT, "%.1f %%", id(euro_change).state);
        it.strftime(120, 300, id(font2), green, TextAlign::CENTER, "%a %d-%m-%Y %H:%M", id(ha_time).now());
My display:
Thanks in advance.
Apparently it’s not easy. I’ve previously tried using std::setlocale(LC_ALL, "de_DE.UTF-8"), but couldn’t get it to work.
A workaround could be to import the HA sensor as a text_sensor and use the substitute filter to replace the point with a comma. You would, of course, have to adjust your printing accordingly.
I’m on my phone, so I can’t test whether this actually would work.
Thanks, I got the correct notation now :+1:t3:
part of code which I changed:
    internal: true
    internal: true
text_sensor:
    filters:
      - substitute:
        - ". -> ," # point to comma
    filters:
      - substitute:
        - "- -> "  # minus sign to space because negative is red color
font:
    extras:
        glyphs: [$,€]
color: # RGB
  - id: red
    hex: cc0000
  - id: green
    hex: '009900'
spi:
  clk_pin: GPIO9
  mosi_pin: GPIO6
display:
  - platform: st7789v
    model: Custom
    width: 240
    height: 320
    offset_height: 0
    offset_width: 0
    rotation: 0
    eightbitcolor: true
    cs_pin: GPIO4
    dc_pin: GPIO3
    reset_pin: GPIO5
    pages:
    - id: page01
      lambda: |-
        it.printf(100, 205, id(font1), white, TextAlign::BASELINE_LEFT, "$ %s", id(euro_price_txt).state.c_str());
        if ((id(euro_change).state) > 0 ) {
          it.printf(240, 205, id(font1), green, TextAlign::BASELINE_RIGHT, "%s %%", id(euro_change_txt).state.c_str());
        } else {
          it.printf(240, 205, id(font1), red, TextAlign::BASELINE_RIGHT, "%s %%", id(euro_change_txt).state.c_str());
