Replaced zigbee stick, configure Home Assistant
I replaced my 2531 usb zigbee stick with a sonoff TI 2562 stick.
Zigbee2mqtt works perfectly and all information is recevied, after adjusting the config file with the new path: /dev/ttyUSB0.
Home Assistant was still configured with the zigbee integration pointing to /dev/ttyACM0. so no data is received anymore from the sensors.
I have deleted the integration and try to add a new one. HA sees the usb device on the correct port. Athough after selecting it, no communication can be made.
Any suggestions how to solve this ?
You can NOT use Zigbee2MQTT and ZHA at the same time with a single zigbee coordinator
Ok, so what do I do to get my zigbee data into HA ?
You must use a MQTT broker and install the MQTT integration with auto discovery enabled
