I’ve been using the Energy Dashboard for over two years and already have a lot of historical data.
Currently, I’m using the Toon Smartmeter integration (configured via configuration.yaml).
Later this month, my electricity, gas, and water meters will be replaced with digital ones.
As a result, I won’t be able to use the Toon Smartmeter integration anymore and will switch to a Smartgateway P1 meter.
This means I’ll get entirely new entities, and the Toon Smartmeter integration will be removed.
However, this also means I will lose all my historical data from the Toon Smartmeter integration.
It should be possible to retain the data in the Energy Dashboard, even after removing the original entities.
So I have had old device that ended with 30000kwh, now new one started on 0.
My meter changed and also I need new device to read it.
How do I continue in HA so it adds new value to old ones?
As Going from 300000 to 1 would make it think it is export of 30000kWh or something.
I am currently using a CircuitSetup EM programmed through ESPHome but I would like to swap over to an Emporia Vue 3 also programmed through ESPHome. What would be the best way to swap over while maintaining historical data?
