Replacing Yeelight Candela MCU with ESP32-C3 (ESPHome Integration)
I finally had some time to document the full process of replacing the original Yeelight Candela MCU with an ESP32-C3 Super Mini and integrating it with ESPHome.
This mod allows full control of the lamp via Home Assistant while keeping the original rotary encoder functionality.
:wrench: What this project includes
  • Complete disassembly steps
  • Removal of the original daughter board
  • Wiring diagram and GPIO mapping
  • ESPHome configuration (included in the repo)
  • Integration with Home Assistant
:sparkles: Features
  • Control Yeelight Candela trough Home Assistant
  • Control brightness via rotary encoder
  • Toggle night mode automatically with an specific rotary encoder turn
:warning: Requirements
  • Soldering skills & basic electronics knowledge
  • A multimeter
  • Solder and wires
  • Hot air gun
:camera_with_flash: Hardware & Wiring
:package: Repository
:backhand_index_pointing_right: GitHub repo: esphome-yeelight-candela-lamp
Now, you can toggle the night mode when you turn on your Candela Lamp, or set a timer for it to fade out too! :tada:
I’ll try. Thank you!
You are welcome.
Thank you for your previous post!
Wow this is amazing, thanks a lot! You made an entire project guide :smiley: I can’t wait to try it myself. Very nice work!
Hey guys, did you hack your Yeelight Candela? I want to see how are your DIY projects going on!
