Replaying a "Universal 24V Fan Controller" (rtl_433 decoder #286) remote — fan doesn't respond despite clean, checksum-valid transmissions
Hi everyone!
I’m trying to find support in using a ESP32 device to replicate the RF signals of two 433 MHz remotes that control 2 ceiling fans so that I can automate them in HA. I tried multiple receivers and transmitters, together with a SDR dongle and SDR_433, but I’ve had no luck so far. I’m trying to summarize my findings below.
Goal
Replace/replicate two physical 433MHz remotes (Eubea DC ceiling fans, rebranded “UniFan-24V” / rtl_433 decoder #286, “Universal (Reverseable) 24V Fan Controller”) with an ESP32-based transmitter, so Home Assistant can control the fans directly.
Protocol (confirmed via rtl_433 decoder #286 source)
  • OOK, PWM encoding
  • 0 = 756µs pulse + 252µs gap; 1 = 256µs pulse + 756µs gap
  • Sync pulse ~3616µs, frame repeated ~7x with ~8200µs gaps
  • 33-bit frame: 20-bit address, 5-bit button code, 3-bit repeat-index (not a security rolling code — just a frame-repeat counter, confirmed by observing it cycle 0-7 automatically every ~2s independent of button presses), 4-bit checksum (XOR-fold of first 4 bytes must equal 0xA), 1 fixed trailing bit
  • Real remote’s Transmitter button codes confirmed via live capture: All Off=25, Speed 1-6=15/13/3/21/16/19, Fan(Breeze)=10, Fan Off=9, Forward=27, Reverse=14. Light-related buttons (Light On/Off=30, Luminance+=17, Luminance-=28) decode as “Unknown” in the generic decoder table but pass checksum validation — likely a manufacturer-specific overlay on the base protocol.
What’s confirmed working
  • Real remote reliably controls the fan from ~20-25 meters through multiple concrete floors (fan audibly beeps on accepted commands)
  • Reconstructed frames (encoded from scratch using the known protocol spec, not replayed captures) pass checksum validation and decode correctly via rtl_433 as valid {33} frames matching the intended button code
  • Real remote’s actual carrier measured via RTL-SDR: ~433.902-433.906 MHz (varies slightly run to run), about -14 to -18 kHz off nominal 433.92 MHz
Hardware tried
  1. ESP32 + STX882 (fixed SAW resonator ASK TX module) — clean, checksum-valid transmissions confirmed via rtl_433, but carrier consistently ~+37 to +38 kHz off nominal (measured against the real remote’s ~433.906 MHz, this module sits close to 433.958 MHz) — no fan response even at point-blank range
  2. ESP32 + FS1000A (same class of module) — same story, carrier off by +49 to +55 kHz, no fan response
  3. ESP32 + CC1101 (SPI-controlled synthesizer transceiver, native ESPHome cc1101: component, dual-pin wiring GDO0→remote_transmitter, GDO2 unused) — frequency is programmable and was tuned to match the real remote (~433.906-433.923MHz tried, converged to within ~3kHz of the real remote’s measured carrier via side-by-side RTL-SDR comparison) — still no fan response even at point-blank range, despite matching peak signal strength (~-20dB) to the real remote on the same SDR at the same distance
The open anomaly
With the CC1101, rtl_433 (-A pulse analyzer mode) intermittently fails to decode the transmission at all (“Guessing modulation: No clue…”, garbled pulse widths mixed with the expected 772µs/272µs timing — spurious ~48-170µs fragments appear inconsistently). This happens unpredictably: same config, same distance, sometimes decodes perfectly ({33}7a3fcc838-style clean output matching intended payload), sometimes fails completely. Not clearly correlated with power level (10dBm vs 11dBm), distance, or the specific frequency setting tried.
What would help
  • Has anyone seen this generic-24V-fan-controller protocol before, or knows if there’s a receiver-side quirk (minimum RSSI gate, specific preamble requirement, timing tolerance) beyond what rtl_433’s generic decoder captures?
  • Any experience with CC1101 native ESPHome component producing intermittent/garbled OOK output specifically (vs. clean output at other times) — config issue vs. hardware fault?
  • Suggestions for isolating “digital pulse train from ESP32/CC1101 before RF stage” — planning to use a logic analyzer/oscilloscope to probe the actual GDO0 pin directly, bypassing RF entirely, as the next diagnostic step, and would appreciate validation that this is the right next move vs. something else worth trying first.
Tools/references used so far
All your hardware should (and has been proved to) work with esphome.
Ceiling fan remotes / protocols are not anyhow “universal” though.
Hi again!
Indeed they’re not that friendly to fiddle with…
Anyway, I found the issue: someone (in another forum) suggested to record signals and inspect their spectrum on https://triq.org/pdv3/. What pdv3 was able to reveal what the summary stats never did: the two signals had different modulation structure.
  • Real remote: Guessing modulation: Pulse Width Modulation with **multiple packets** — no sync pulse, just repeated frames separated by inter-frame gaps.
  • My transmission: Guessing modulation: Pulse Width Modulation with **sync/delimiter** — I had a ~3616µs sync pulse in front of every repeat.
I’d added that sync pulse based on a comment in the universalfanctrl decoder source (src/devices/unifan.c) mentioning “a transmission starts with a pulse of 3616 us.” Turns out rtl_433’s generic pulse slicer is flexible enough to find and decode the real 33-bit frame regardless of whether that extra pulse is there or not — so every one of my -A/-R 286 captures decoded perfectly, checksum passed, address/button code all correct, for months. The fan’s actual receiver, unsurprisingly, was far less forgiving than rtl_433’s decoder and just ignored the malformed transmission outright.
Removed the sync pulse so each repeat is just the bit-encoded frame back-to-back (separated only by the ~8200µs inter-frame gap), reflashed, and the fan responded immediately.
I guess I can tag this as solved.
