Report HomeAssistant network status on Dashboard
I have Home Assistant running HAOS connected to two networks at the same time: Ethernet and Wifi.
The primary connection is the wired connection, with the Wifi connecting to an isolated network to pull monitoring data.
The Wifi connection tends to disconnect from time to time, and the I need to manually reconnect by reentering the wifi connection settings.
Is there some why I can raise an alert or show the HAOS wifi connection status on a dashboard which will show me HAOS has disconnected from the wifi?
Hello Jan,
Look at the ping integration.
