Logger: zigpy_znp.uart
Source: /usr/local/lib/python3.13/site-packages/zigpy_znp/uart.py:58
First occurred: 11 February 2025 at 23:43:04 (5 occurrences)
Last logged: 11 February 2025 at 23:46:29
Received an exception while passing frame to API: TransportFrame(payload=GeneralFrame(header=CommandHeader(id=0xB2, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\xA2\xCF\x84'))
Received an exception while passing frame to API: TransportFrame(payload=GeneralFrame(header=CommandHeader(id=0xB2, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\x6F\x00\x84'))
Received an exception while passing frame to API: TransportFrame(payload=GeneralFrame(header=CommandHeader(id=0xB2, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\x03\x44\x84'))
Received an exception while passing frame to API: TransportFrame(payload=GeneralFrame(header=CommandHeader(id=0xB2, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\x5D\xBA\x84'))
Received an exception while passing frame to API: TransportFrame(payload=GeneralFrame(header=CommandHeader(id=0xB2, subsystem=Subsystem.ZDO, type=CommandType.AREQ), data=b'\x42\x33\x84'))
File "/usr/local/lib/python3.13/site-packages/zigpy_znp/types/commands.py", line 417, in from_frame
params[param.name], data = param.type.deserialize(data)
File "/usr/local/lib/python3.13/site-packages/zigpy/types/struct.py", line 319, in deserialize
value, data = field_type.deserialize(data)
File "/usr/local/lib/python3.13/site-packages/zigpy/types/basic.py", line 199, in deserialize
raise ValueError(f"Data is too short to contain {byte_size} bytes")
ValueError: Data is too short to contain 1 bytes
File "/usr/local/lib/python3.13/site-packages/zigpy_znp/uart.py", line 56, in data_received
self._api.frame_received(frame.payload)
File "/usr/local/lib/python3.13/site-packages/zigpy_znp/api.py", line 854, in frame_received
command = command_cls.from_frame(frame, align=self.nvram.align_structs)
File "/usr/local/lib/python3.13/site-packages/zigpy_znp/types/commands.py", line 424, in from_frame
raise ValueError(
...<2 lines>...
ValueError: Frame data is truncated (parsed {'Src': 0xCFA2, 'Status': <Status.NOT_SUPPORTED: 132>}), required parameter remains: Param(name='Routes', type=<class 'zigpy.zdo.types.Routes'>, description='Routes', optional=False)
Anyone understand the significance of this?
