Hi friend,
I cannot seem to access Web UI after installing it fresh, the log shows that port 8080 is in use, which it is, by Pi-Hole.
I tried copying config json into the options box and hitting save but it still gives the port error even though I changed the config to port 8081
Is there any other logs I can check ?
Edit: I changed Pi-Hole to port 8081 instead, and now I can get to UniFi UI, but I cannot complete the wizard…
When I try to upload my config it says an error occurred, If I try to complete manually without my backup it says an error occurred when I click finish
It also prompts for a cloud key update… I skipped for now
Edit 2: I installed firefox and was able to upload my backup, a message popped up that it was restoring, and now I cannot access the web UI :’)
I will give it a few minutes and if nothing still ill restart the addon
Edit 3: After restoring backup, restarting, I am back at the Web UI, however I cannot login…no account I try works… might have to uninstall and start from scratch…
Edit 4: No luck, cant get into the Web UI at all anymore :(((( someone pls help the Unifi software is the only thing left on my Dell R610 I want to decommission it to save power
Edit 5: I GOT IT WORKING
I uninstalled, rebooted the Pi, reinstalled, set up as new, migrated everything over from old to new, uploaded backups to restore, and now it looks like its working ok.
My goodness this has been a fun few hours…
