Request for Independent Code and Preview Views
We need to implement a solution that makes both sides of a configuration card independent, so we can work on the code while keeping the preview visible. This is especially important for vertical cards, as it can be challenging to code and view the preview simultaneously. Additionally, each side should have its own scrollbar.
Like in this case, it’s difficult to see the button preview while editing the code.
Click the card title to expand the card.
It’s more that as you scroll down the code (on the left side), you lose the preview in the top-right side causing you to keep scrolling up and down.
Hello niighthawk,
This appears to be a Frontend Related Feature Request as it is asking for changes to Frontend Menus, Dashboards, or Sections.
These Feature Requests are handled in a different system, and will not be seen by the right people if posted in the HA forums.
Please add your Feature Request into GitHub here:
home-assistant/frontend Other Feature Requests · Discussions · GitHub.
See more info about Feature Requests HERE
