Resend commands to battery powered ESP32
Hi everyone!
I have a slight problem:
I’m using a battery powered ESP32 as a status indicator for a project.
If Home Assistant sends out the status information (= LED 1 on) while the ESP32 isn’t running, that command is “lost” and if I turn on the ESP32 now it’s not doing anything until the status changes.
Is there a way to send out commands regularly even if the status hasn’t changed?
I was thinking:
[if conditions are met]
{repeat}
- “Light turn on”
- “wait 60 seconds”
maybe there’s a smarter way?
Thanks!
maybe doing it the other way around, set it up the way that esphome requests the state.
You can watch a HA entity with something like this and execute whatever you want based on conditions
binary_sensor:
  - platform: homeassistant
    name: "my cool name"
    internal: true
    entity_id: switch.my_id #Change the entity from your Home Assistant
    on_state:
      then:
        - if:
            condition:
              - binary_sensor.is_on: my_cool_id
            then:
              #do something
            else:
              #do something
They also may need to use this setting.
publish_initial_state:
It’s probably a good idea to share your config at this point.
Thanks so much!
The combination of these two made it work!
