Reset Backup Entries?
I used to do backups through command line (ha backup command). The files are stored in /usr/share/hassio/backup
Now my “real” backup solution backed up this folder and I did a restore on it.
For some reason my GUI (Settings → System → Backup) just displays a turning circle and never displays the available backups. “ha backup list” shows them, though.
I would like to delete all files there and reset the backup counter. How to do? Where are the entries stored?
Thanks!
/KNEBB
Do not delete the .tar backup files. Copy them to a thumb drive.
You don’t indicate how your Home Assistant is installed, but mine is the x86 HAOS image. The files are in a folder on the root: /backup
Your problem could be simply not enough storage space. Delete a couple of the older .tar files and try again.
I did not. I removed them from the folder (and indeed stored them on a different place). But that’s not the point.
Missed that, but I stated the files are at /usr/share/hassio/backup so it is a supervised installation based on Debian12.
No way. For sure enough disk space. All backups together use aprox. 4G:
Dateisystem               Größe Benutzt Verf. Verw% Eingehängt auf
udev                       1,9G       0  1,9G    0% /dev
tmpfs                      392M    1,4M  391M    1% /run
/dev/mapper/hoas--vg-root   82G     14G   64G   18% /
tmpfs                      2,0G       0  2,0G    0% /dev/shm
tmpfs                      5,0M       0  5,0M    0% /run/lock
tmpfs                      4,0M       0  4,0M    0% /sys/fs/cgroup
/dev/vda1                  455M     53M  378M   13% /boot
Further ideas?
/KNEBB
I just discoverd the solution. So easy. There seems not to be another place where information about backups are stored.
After I removed all files (and stored them on a different place) AND rebooted the machine (not only HoAssistant) it shows me the empty backups and I can easily create new backups.
Loks like on of the *.tar files is corrupted somehow.
No worries, for a couple of days I will have only small sets of backup but that’s fine with me.
[EDIT] Finally found the correct solution:
ha backup reload
/KNEBB
Why not do a full backup now? (I use the Samba Share add-on to do a full backup every morning at 1:00 AM).
