Respeaker-Lite-ESPHome-integration
Having difficulties with the installation of Respeaker-Lite-ESPHome-integration.
when i try to install the YAML from the project i get this error:
esphome: [source /config/esphome/esphome-web-edb90c.yaml:19]
  'name' is a required option for [esphome].
  project:
    name: formatbce.Respeaker Lite Satellite
    version: 2025.1.3
  min_version: 2024.12.4
  platformio_options:
    board_build.flash_mode: dio
  on_boot:
    priority: 375
    then:
      - sensor.template.publish:
          state: -1
does anyone know what i need to do to fix this error and install the YAML on the ESP?
Please post the full yaml.
At first sight, it doesn’t look like the yaml the project is publishing
esphome:
  friendly_name: ReSpeakerv3
  platformio_options:
    board_build.mcu: esp32s3
  # on_boot:
  #   then:
  #     - if:
  #            condition:
  #              switch.is_on:
  #            then:
  #              - voice_assistant.start_continuous:
esp32:
  board: esp32-s3-devkitc-1
  variant: esp32s3
  framework:
    type: esp-idf
    version: recommended
logger:
  level: VERY_VERBOSE
api:
wifi:
  ssid: "Wi-Fi name"
  password: "Wi-Fi password"
captive_portal:
external_components:
  - source: github://QingWind6/ESPHome_XIAO-ESP32S3
i2s_audio_xiao:
  i2s_lrclk_pin: GPIO7
  i2s_bclk_pin: GPIO8
  i2s_mclk_pin: GPIO9
microphone:
  - platform: i2s_audio_xiao
    adc_type: external
    i2s_din_pin: GPIO44
    pdm: false
    bits_per_sample: 32bit
    channel: left
speaker:
    dac_type: external
    i2s_dout_pin: GPIO43
    mode: stereo
voice_assistant:
  microphone: xiao_mic
  use_wake_word: true
  noise_suppression_level: 0
  auto_gain: 0dBFS
  volume_multiplier: 1
  speaker: xiao_speaker
  on_listening:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        effect: "Slow Pulse"
  on_stt_vad_end:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        effect: "Fast Pulse"
  on_tts_start:
    - light.turn_on:
        blue: 100%
        red: 0%
        green: 0%
        brightness: 100%
        effect: none
  on_end:
    - delay: 100ms
    - wait_until:
        not:
          speaker.is_playing:
    - script.execute: reset_led
  on_error:
    - light.turn_on:
        red: 100%
        green: 0%
        blue: 0%
        brightness: 100%
        effect: none
    - delay: 1s
  on_client_connected:
    - if:
        condition:
          switch.is_on: use_wake_word
        then:
  on_client_disconnected:
    - if:
        condition:
        then:
          - voice_assistant.stop:
          - light.turn_off: led
light:
  - platform: esp32_rmt_led_strip
    disabled_by_default: true
    entity_category: config
    pin: GPIO1
    default_transition_length: 0s
    chipset: ws2812
    num_leds: 1
    rgb_order: grb
    rmt_channel: 0
    effects:
      - pulse:
          transition_length: 250ms
          update_interval: 250ms
          min_brightness: 50%
          max_brightness: 100%
      - pulse:
          transition_length: 100ms
          update_interval: 100ms
          min_brightness: 50%
output:
  - platform: ledc
    pin: GPIO21
    inverted: true
script:
  - id: reset_led
    then:
      - if:
          condition:
            - switch.is_on: use_wake_word
            - switch.is_on: use_listen_light
          then:
            - light.turn_on:
                effect: none
          else:
            - light.turn_off:
switch:
    name: Use wake word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    on_turn_on:
      - lambda: id(assist).set_use_wake_word(true);
      - if:
          condition:
            not:
              - voice_assistant.is_running
          then:
    on_turn_off:
      - lambda: id(assist).set_use_wake_word(false);
    name: Use Listen Light
    optimistic: true
    on_turn_on:
    on_turn_off:
