Response payload is not completed
I am having some pretty random issue with my home network? my ISP? which manifests as
  • small updates to HACS components or to Add-ins install OK
  • larger updates such as Frigate or HA itself fail with messages like the below
  • ESPhome updated OK, but compiling an ESP project fails when downloading the .zip bundles it needs
HA is wired ethernet direct to the router
I have disabled IPv6 in HA
I have disabled ad-blocking in Adguard, and changed HA to use unfiltered DNS
I have tried reducing the MTU on my HA instance ethernet interface to 1400
Browser network tests such as speedtest.net and https://speed.cloudflare.com/ show no issues
Taking the URLs from the error log and downloading them in the browser fails, but browser downloads are resumable. Resuming continues for a few tens of MB before failing again
Any suggestions where else to look? Has anyone else seen similar?
Logger: homeassistant.components.websocket_api.http.connection
Source: components/websocket_api/commands.py:317
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 00:51:15 (10 occurrences)
Last logged: 13:53:42
[140633597865760] Error during service call to update.install: Error updating Home Assistant Operating System: Can't fetch OTA update from https://os-artifacts.home-assistant.io/16.3/haos_generic-x86-64-16.3.raucb: Response payload is not completed: <ContentLengthError: 400, message='Not enough data to satisfy content length header.'>. ConnectionResetError(104, 'Connection reset by peer')
[140633597865760] Error during service call to update.install: Error updating Frigate: read tcp 192.168.1.5:52348->185.199.108.154:443: read: connection reset by peer
[140633618916320] Error during service call to update.install: Error updating Home Assistant Operating System: Can't fetch OTA update from https://os-artifacts.home-assistant.io/16.3/haos_generic-x86-64-16.3.raucb: Response payload is not completed: <ContentLengthError: 400, message='Not enough data to satisfy content length header.'>. ConnectionResetError(104, 'Connection reset by peer')
[140633587086848] Error during service call to update.install: Error updating Home Assistant Operating System: Can't fetch OTA update from https://os-artifacts.home-assistant.io/16.3/haos_generic-x86-64-16.3.raucb: Response payload is not completed: <ContentLengthError: 400, message='Not enough data to satisfy content length header.'>. ConnectionResetError(104, 'Connection reset by peer')
[140633587086848] Error during service call to update.install: Error updating Frigate: read tcp 192.168.1.5:36754->185.199.110.154:443: read: connection reset by peer
2025-11-05 14:16:17.620 homeassistant NetworkManager[464]: <info>  [1762352177.6202] manager: NetworkManager state is now CONNECTED_GLOBAL
2025-11-05 14:16:17.645 homeassistant systemd[1]: systemd-timesyncd.service: Deactivated successfully.
2025-11-05 14:16:17.646 homeassistant systemd[1]: Stopped Network Time Synchronization.
2025-11-05 14:16:17.649 homeassistant systemd[1]: Starting Network Time Synchronization...
2025-11-05 14:16:17.830 homeassistant systemd[1]: Started Network Time Synchronization.
2025-11-05 14:16:17.982 homeassistant systemd-timesyncd[225898]: Contacted time server 132.163.97.1:123 (132.163.97.1).
2025-11-05 14:16:17.983 homeassistant systemd-timesyncd[225898]: Initial clock synchronization to Wed 2025-11-05 14:16:18.027878 GMT.
2025-11-05 14:16:27.848 homeassistant systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
2025-11-05 14:16:33.882 homeassistant dockerd[588]: time="2025-11-05T14:16:33.882268264Z" level=info msg="Download failed, retrying (1/5): read tcp 192.168.1.5:33424->185.199.108.154:443: read: connection reset by peer"
2025-11-05 14:16:33.901 homeassistant dockerd[588]: time="2025-11-05T14:16:33.901648525Z" level=info msg="Download failed, retrying (1/5): read tcp 192.168.1.5:33422->185.199.108.154:443: read: connection reset by peer"
2025-11-05 14:16:42.103 homeassistant dockerd[588]: time="2025-11-05T14:16:42.103312779Z" level=info msg="Download failed, retrying (1/5): read tcp 192.168.1.5:53906->185.199.109.154:443: read: connection reset by peer"
2025-11-05 14:16:42.107 homeassistant dockerd[588]: time="2025-11-05T14:16:42.107186822Z" level=info msg="Download failed, retrying (2/5): read tcp 192.168.1.5:33440->185.199.108.154:443: read: connection reset by peer"
2025-11-05 14:16:42.109 homeassistant dockerd[588]: time="2025-11-05T14:16:42.109471491Z" level=info msg="Download failed, retrying (2/5): read tcp 192.168.1.5:33436->185.199.108.154:443: read: connection reset by peer"
2025-11-05 14:16:58.859 homeassistant dockerd[588]: time="2025-11-05T14:16:58.857434323Z" level=info msg="Download failed, retrying (2/5): read tcp 192.168.1.5:34350->185.199.109.154:443: read: connection reset by peer"
2025-11-05 14:16:58.889 homeassistant dockerd[588]: time="2025-11-05T14:16:58.889464499Z" level=info msg="Download failed, retrying (3/5): read tcp 192.168.1.5:44708->185.199.111.154:443: read: connection reset by peer"
2025-11-05 14:16:58.891 homeassistant dockerd[588]: time="2025-11-05T14:16:58.891392450Z" level=info msg="Download failed, retrying (3/5): read tcp 192.168.1.5:50340->185.199.109.154:443: read: connection reset by peer"
I should have said, browser downloads of large files from other sources seem fine and no-one else in the house has noticed anything amiss; two adults working from home plus a child gaming successfully
Retry 1/5 in your error log seems to give confidence that it is trying.
Is traffic inspection tools and configuring routing traffic category priorities on your router high on your agenda in a mixed network environment?
Have you done a ping and trace to that remote IP? They may be having issues, or your internet path routing to them may be faulty, something you have not control over.
Do you have a rogue network device that is saturating your network with interference?
Have you tried a fresh update when everybody has gone to bed and the network is quieter? Beware of kids downloading big game updates overnight however.
I’ve noticed a few other docker update/network error type problems logged here. Maybe the problem is external to your home network.
Retry and see if it has been resolved.
I’m now convinced that the problem is external to my home network - I have logged a support request with my ISP. The oddest thing is that this affects github.com sites but not raspberrypi.org
My ISP did not respond to my query, but everything started working as expected and all elements are now updated.
