Response variable value contains ">"
I’m trying to pass a response.response_text into an input text helper. If the response is short enough to not include the “>” in it it works fine, if however it does include “>” the text helper doesn’t get updated. Besides ensuring the response is short enough to not include that is there a way to make this work?
action: input_text.set_value
metadata: {}
  value: "{{response.response_text}}"
  entity_id: input_text.blah
Doesn’t work:
response:
  response_text: >
    Neither a person nor a package is visible at the front door in the image.
    There is a small container on a folding chair near the door, but it's
    unclear what's inside.
Works:
response:
  response_text: |
    Neither.  There is a small container on a chair near the door.
No. An input_text helper can hold a maximum of 255 characters, or less if you have set a different limit. Either truncate the string to fit, or I suppose use an AI or something to summarize it…
value: "{{ response.response_text[:254]~'…' if response.response_text | length >= 255 else response.response_text }}"
Thanks, that explains it. An LLM is generating the text so I just tell it to be concise and it works.
