Rest sensor => extract a specific line / value
Hey i have a rest sensor that executes a .js file
the output is more then 255 chars, i am only interested in this line:
minValue: { rawValue: 0, value: 0, valueType: 'RELATIVE' },
or even better, only the “value” => 0
this is my rest sensor, but it doesnt work, help is appreciated
  - platform: rest
    resource: http://192.168.0.17:8123/local/test.js
    scan_interval: 500
    value_template: '{{ value | regex_findall_index("minValue: { rawValue: 0, value:(\d+)", ignorecase=true) | int }}'
Can you post the full output?
yes, if i do it from command line, this is complete output
  api: 788,
  apiText: 'GW_LIMITATION_STATUS_NTF',
  sessionID: 1,
  nodeID: 0,
  parameterID: 0,
  parameterTyp: undefined,
  parameterText: undefined,
  maxValue: { rawValue: 63487, value: null, valueType: 'RELATIVE' },
  limitationOriginator: 255,
  limitationOriginatorTyp: 'EMERGENCY',
  limitationOriginatorText: 'Used in context with emergency or security',
  limitationTime: 255
@tom_l
Is there also a way to actually see the 255 max character string in some log file? I want to see if the command was successful in first case
