kludge
(kludge)
1
I am attempting to call keycloak’s API to retrieve a JWT in order to auth with an API I am self hosting.
My rest sensor configs are:
- platform: rest
resource: http://192.168.1.136:28080/auth/realms/master/protocol/openid-connect/token
method: POST
scan_interval: 1
value_template: "{{ value_json }}"
payload: '{"grant_type=client_credentials&client_id=homeassistant&client_secret=nope"}'
headers:
Content-Type: application/x-www-form-urlencoded
I have to include the brackets before and after the url-encoded payload in order for HA to send the request successfully.
The issue, they are sent to keycloak, which makes the request fail.
pcap screenshot:
Is this a limitation/bug with the rest sensor or I am doing something incorrect?
kludge
(kludge)
2
Bumping to hopefully get an answer.
mekaneck
(Rick Auch)
3
Sorry I don’t have anything where I can try this, so I can only provide unverified guesses:
Can you send the payload as a dict
to see if it gets form encoded?
payload: '{"grant_type":"client_credentials", "client_id":"homeassistant", "client_secret":"nope"}'
or perhaps:
payload: '{"grant_type":"client_credentials", "client_id":"homeassistant", "client_secret":"nope"} | tojson'
w35l3y
(w35l3y)
4
What is the expected content type ?
It seems you are mixing things.
Have you tried to use the code below ?
payload:
grant_type: client_credentials
client_id: homeassistant
client_secret: nope
headers:
Content-Type: application/json
I don’t know if it will work.
It depends on the expected content type.
kludge
(kludge)
5
I ended up using curl in a command_line sensor
