Hi fellas,
I have a new question. I have a xmpp Server running and I would like to use the Rest sensor to control/read out some data from it.#
I have an example here. This is a curl command:
curl -u '[email protected]:password' -X POST -d '{"user": "thorsten", "host": "emevth.no-ip.biz"}' 192.168.1.100:5280/api/user_sessions_info
This is the output:
[{"connection":"c2s_tls","ip":"192.168.1.1","port":63985,"priority":0,"node":"ejabberd@localhost","uptime":16462,"status":"available","resource":"dino.f165760e","statustext":""},{"connection":"c2s_tls","ip":"192.168.1.1","port":49774,"priority":0,"node":"ejabberd@localhost","uptime":15467,"status":"available","resource":"Pix-Art Messenger.ifvW","statustext":"Renovieren.... Renovieren..Mund nochmals Renovieren š¾"},{"connection":"c2s_tls","ip":"192.168.1.1","port":56410,"priority":0,"node":"ejabberd@localhost","uptime":16556,"status":"available","resource":"3825852600576074643603970","statustext":"thorsten is online"}]
Any idea how I can get this into a rest sensor? Please see that I use username and password for the curl command
Thanks for the answers
