Systeminfo:
VMWare ESXi
Operating system HassOS 4.13 production
HA Version: 0.116.3
Supervisor Version 247
QinHeng USB2.0-Serial
Restarting HA gives an error when restarting: serial.serialutil.SerialException: [Errno 5] could not open port
The serial connection is made via a USB to RS232 for the DSMR.
File "/usr/src/homeassistant/homeassistant/components/dsmr/sensor.py", line 158, in connect_and_reconnect
transport, protocol = await hass.loop.create_task(reader_factory())
File "/usr/local/lib/python3.8/asyncio/coroutines.py", line 124, in coro
res = func(*args, **kw)
File "/usr/local/lib/python3.8/site-packages/serial_asyncio/__init__.py", line 410, in create_serial_connection
ser = serial.serial_for_url(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/serial/__init__.py", line 88, in serial_for_url
instance.open()
File "/usr/local/lib/python3.8/site-packages/serial/serialposix.py", line 268, in open
raise SerialException(msg.errno, "could not open port {}: {}".format(self._port, msg))
serial.serialutil.SerialException: [Errno 5] could not open port /dev/serial/by-id/usb-1a86_USB2.0-Ser_-if00-port0: [Errno 5] I/O error: '/dev/serial/by-id/usb-1a86_USB2.0-Ser_-if00-port0'
2020-10-15 19:28:16 ERROR (MainThread) [homeassistant.components.dsmr.sensor] Error connecting to DSMR
File "/usr/local/lib/python3.8/site-packages/serial/serialposix.py", line 265, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
OSError: [Errno 5] I/O error: '/dev/serial/by-id/usb-1a86_USB2.0-Ser_-if00-port0'
It happens only when I restart HA. Rebooting solves the problem.
Restarting cost way more time than rebooting the whole system. It is waiting for the serial adapter to finish which never does.
This HA is running in a VM environment and the console screen shows:
It happened after a few updates ago and was I not aware what was going on. Newer updates did not fix it.
Can this issue be a driver related thing?
