Restarted HOST and HA not starting
Made a shutdown of host (R Pi + SSD) and HA is not starting (and nothing is showing in the logfile).
This morning I restarted the host and after it worked fine and in the meantime no changes were made.
Any idea how I can troubleshoot this problem? I am running HA in a docker
In my opinion it seems Supervisor is not starting, but I am not an expert of such things. Any help will be appreciated. (Note I should have backup taken during the night)
pi@raspberrypi:~ $ sudo docker container ls -a
CONTAINER ID        IMAGE                                         COMMAND                  CREATED             STATUS                           PORTS                    NAMES
b99fb989c255        homeassistant/armv7-addon-letsencrypt:4.8.0   "/init"                  15 hours ago        Exited (0) 15 hours ago                                   addon_core_letsencrypt
96e909114cba        hassioaddons/influxdb-armv7:3.7.1             "/init"                  24 hours ago        Exited (255) About an hour ago   0.0.0.0:8086->8086/tcp   addon_a0d7b954_influxdb
f3b6aa8ea472        homeassistant/armv7-addon-ssh:8.6.0           "/init"                  24 hours ago        Exited (255) About an hour ago                            addon_core_ssh
ec5db3860b40        hassioaddons/grafana-armv7:5.1.1              "/init"                  24 hours ago        Exited (129) 35 minutes ago                               addon_a0d7b954_grafana
c45a43df2be7        homeassistant/armv7-addon-mariadb:2.1.2       "/init"                  24 hours ago        Exited (255) About an hour ago                            addon_core_mariadb
cdd400cb27f9        homeassistant/armv7-hassio-multicast:2        "/init"                  24 hours ago        Exited (255) About an hour ago                            hassio_multicast
1972c7f88d38        homeassistant/armv7-hassio-cli:25             "/init /bin/bash -c …"   24 hours ago        Exited (255) About an hour ago                            hassio_cli
8d65b65eddef        homeassistant/armv7-hassio-audio:14           "/init"                  24 hours ago        Exited (255) About an hour ago                            hassio_audio
cd925cf6bcf0        homeassistant/armv7-hassio-dns:9              "/init coredns -con
EDIT - it seems docker is not starting
root@raspberrypi:~# systemctl status docker.service
● docker.service - Docker Application Container Engine
   Loaded: loaded (/lib/systemd/system/docker.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Fri 2020-06-19 14:51:51 BST; 15s ago
     Docs: https://docs.docker.com
  Process: 9057 ExecStart=/usr/bin/dockerd -H fd:// --containerd=/run/containerd/containerd.sock (code=exited, status=2)
 Main PID: 9057 (code=exited, status=2)
      CPU: 1.583s
Jun 19 14:51:49 raspberrypi systemd[1]: docker.service: Main process exited, code=exited, status=2/INVALIDARGUMENT
Jun 19 14:51:49 raspberrypi systemd[1]: Failed to start Docker Application Container Engine.
Jun 19 14:51:49 raspberrypi systemd[1]: docker.service: Unit entered failed state.
Jun 19 14:51:49 raspberrypi systemd[1]: docker.service: Failed with result 'exit-code'.
Jun 19 14:51:51 raspberrypi systemd[1]: docker.service: Service hold-off time over, scheduling restart.
Jun 19 14:51:51 raspberrypi systemd[1]: Stopped Docker Application Container Engine.
Jun 19 14:51:51 raspberrypi systemd[1]: docker.service: Start request repeated too quickly.
Jun 19 14:51:51 raspberrypi systemd[1]: Failed to start Docker Application Container Engine.
Jun 19 14:51:51 raspberrypi systemd[1]: docker.service: Unit entered failed state.
Jun 19 14:51:51 raspberrypi systemd[1]: docker.service: Failed with result 'exit-code'.
