RESTful command client error
Hello everybody!
Tried to set up a RESTful command to turn a webcams recording feature on and off (see below). As this is my first step into HA RESTful commands any help or tips would be kindly appreciated - thank you! :heart:
This here is the link to its API documentation which tells me to change the configuration taking into account:
Set configuration
http://IP_CAM/cgi-bin/set_configs.sh?conf=CONF
CONF action
system Update system configuration
Need POST method with a json file.
The relevant system setting and its payload within would be:
"REC_WITHOUT_CLOUD":"yes",
And my RESTful service is:
rest_command:
  cam_eg_surveillance_on:
    url: "http://username:[email protected]:8080/cgi-bin/set_configs.sh?conf=system"
    method: POST
    payload: "REC_WITHOUT_CLOUD=yes"
    content_type: 'application/json; charset=utf-8'
  cam_eg_surveillance_off:
    method: POST
    payload: "REC_WITHOUT_CLOUD=no"
But when I call the service I get only
Error: Client error occurred when calling resource "http://username:[email protected]:8080/cgi-bin/set_configs.sh?conf=system"
Result:
params:
  domain: rest_command
  service: cam_eg_surveillance_off
  service_data: {}
  target: {}
running_script: false
I’m getting the same with a request within the lan.
  • Core 2024.5.5
  • Supervisor 2024.05.1
  • Operating System 12.3
  • Frontend 20240501.1
Solution is coming!!
:partying_face:
Correct syntax must be like this:
rest_command:
    url: "http://0.0.0.0/cgi-bin/set_configs.sh?conf=system"
    username: “username“
    password: “password“
    method: POST
    payload: ‘{"REC_WITHOUT_CLOUD“:“yes"}‘
    method: POST
    payload: ‘{"REC_WITHOUT_CLOUD“:“no"}‘
As you can see I pulled out the username and pass from the url and especially changed payload formatting!
Working like a charm now!
in my case I don’t have http auth on the url, I’ll try to debug what’s going on and write here my results.
