RESTful sensor parse incoming data / array
Hi I have an energymanager (solar watt) that has provides the measurement as REST/JSON.
However the needed keys are stored in the JSON response object in a list/array (some kind of a list iteration for the connected devices)
My problem ist the Json keys I’m interested are not always in the same order, so not always on the same place in the Json list.
E.g. for PowerConsumedFromGrid:
 cat 1.json | jq -c 'paths | select(.[-1] == "PowerConsumedFromGrid")'
["result","items",8,"tagValues","PowerConsumedFromGrid"]
curl http://energymanager.local/rest/kiwigrid/wizard/devices |jq -c 'paths | select(.[-1] == "PowerConsumedFromGrid")'
["result","items",3,"tagValues","PowerConsumedFromGrid"]
So this Value is sometimes
value_template: "{{ value_json.result.items[8].tagValues.PowerConsumedFromGrid.value }}"
and sometimes:
and maybe any other index in this litem ist.
The result json looks like:
    "result": {
        "items": [
                "tagValues": {
                    "PowerConsumedFromGrid": {...}
                    "PowerOut": {...}
                    #  100 more
                "tagValues": {
                    "StateOfCharge": { ..}
            # and so on
Any hint how I can parse this with the restful integration?
There’s probably an elegant way to filter the list using selectattr() but I couldn’t figure it out. Here is a sledgehammer approach that just loops through every item in the list:
{% for item in value_json.result['items'] -%}
  {% if item.tagValues.PowerConsumedFromGrid is defined %}
    {{- item.tagValues.PowerConsumedFromGrid.value -}}
  {% endif %}
{%- endfor %}
You can use something like has(‘PowerConsumedFromGrid’) in JQ but as your data/result is half presented cannot help more
Please post full, valid JSON in future to save us having to manually recreate something. Assuming I’ve done it correctly:
{{ (value_json['result']['items']
    |selectattr('PowerConsumedFromGrid','defined')
    |map(attribute='PowerConsumedFromGrid')
    |first)['value'] }}
Hi thanks for the answers of far. And sorry not providing the full result json (its long and I didn’t want to spam here.)
So here is a (still shortened, full has 5k lines) sample (with the key I’m interested at the moment in item[5] & item[8]):
    "result": {
        "items": [
                "tagValues": {
                    "Schedule": {
                        "tagName": "Schedule",
                        "guid": "urn:app:schedule:ERC05-000003672",
                        "value": []
                    "DegreeInclination": {
                        "tagName": "DegreeInclination",
                        "guid": "a53bcedb-1511-4ed2-afcc-e9e7563100f3",
                        "value": 5
                    "WorkAnnualYield": {
                        "tagName": "WorkAnnualYield",
                        "value": null
                    "PasswordLock": {
                        "tagName": "PasswordLock",
                        "value": null
                "deviceModel": [
                        "deviceClass": "com.kiwigrid.devices.pvplant.PVPlant"
                "tagValues": {
                    "PasswordLock": {
                        "guid": "urn:kiwigrid:gridflow:ERC05-000003672",
                        "value": null
                    "CurrentLimit": {
                        "tagName": "CurrentLimit",
                        "value": 50
                    "IdName": {
                        "tagName": "IdName",
                        "value": "GridFlow"
                "deviceModel": [
                        "deviceClass": "com.kiwigrid.kiwiapp.gridflow.GridFlow"
                "tagValues": {
                    "IdLabelSet": {
                        "tagName": "IdLabelSet",
                        "guid": "ERC05-000003672",
                        "value": null
                    "VersionExtensionsMap": {
                        "tagName": "VersionExtensionsMap",
                        "value": {
                            "energymanager-rail": "7.23.0.0"
                    "URLCloud": {
                        "tagName": "URLCloud",
                        "value": "auth.kiwigrid.com"
                    "StateVisibleIsSet": {
                        "tagName": "StateVisibleIsSet",
                        "value": false
                "deviceModel": [
                        "deviceClass": "com.kiwigrid.devices.em.EnergyManager"
                "tagValues": {
                    "IdProfileActive": {
                        "tagName": "IdProfileActive",
                        "guid": "urn:app:profile:ERC05-000003672",
                        "value": "1594299120866"
                    "IdModelCode": {
                        "tagName": "IdModelCode",
                        "value": null
                    "IdPriorizedDeviceList": {
                        "tagName": "IdPriorizedDeviceList",
                        "value": []
                "deviceModel": [
                        "deviceClass": "com.kiwigrid.application.schedule.ProfileApp"
                "tagValues": {
                    "FactorForecastCAN": {
                        "tagName": "FactorForecastCAN",
                        "guid": "urn:solarwatt:myreserve:bc:a30b000b4cc7",
                        "value": "01 00 00 00 00 00 00 00 "
                    "VoltageBatteryCellMean": {
                        "tagName": "VoltageBatteryCellMean",
                        "value": 4.005
                    "PowerACInMax": {
                        "tagName": "PowerACInMax",
                        "value": null
                    "TimeEqualizingChargeRemaining": {
                        "tagName": "TimeEqualizingChargeRemaining",
                        "value": null
                    "TemperatureBattery": {
                        "tagName": "TemperatureBattery",
                        "value": 23
                    "VoltageBatteryString": {
                        "tagName": "VoltageBatteryString",
                        "value": 96.09999999999997
                    "PowerACIn": {
                        "tagName": "PowerACIn",
                        "value": 118.97179999999996
                    "StateOfHealth": {
                        "tagName": "StateOfHealth",
                        "value": 96
                    "StateOfCharge": {
                        "tagName": "StateOfCharge",
                        "value": 82.5
                    "TemperatureBatteryCellMax": {
                        "tagName": "TemperatureBatteryCellMax",
                        "value": 36
                    "ModeConverter": {
                        "tagName": "ModeConverter",
                        "value": "CHARGING"
                    "VoltageBatteryCellMax": {
                        "tagName": "VoltageBatteryCellMax",
                        "value": 4.008
                    "CurrentBatteryOut": {
                        "tagName": "CurrentBatteryOut",
                        "value": 0
                "deviceModel": [
                        "deviceClass": "com.kiwigrid.devices.solarwatt.MyReserve"
                "tagValues": {
                    "PowerOut": {
                        "tagName": "PowerOut",
                        "guid": "4383bfde-a779-4a2b-a8da-b2c48ef3f393",
                        "value": 16
                    "DirectionMetering": {
                        "tagName": "DirectionMetering",
                        "value": "BIDIRECTIONAL"
                     "ActivePowerL1": {
                        "tagName": "ActivePowerL1",
                        "value": null
                "deviceModel": [
                        "deviceClass": "com.kiwigrid.devices.solarwatt.MyReservePowermeter"
                "tagValues": {
                    "StateDevice": {
                        "tagName": "StateDevice",
                        "guid": "urn:solarwatt:myreserve:pv:a30b000b4cc7",
                        "value": "OK"
                    "ACPower": {
                        "tagName": "ACPower",
                        "value": null
                    "WorkACOut": {
                        "tagName": "WorkACOut",
                        "value": 2.5216984823312838E7
                    "PowerACOut": {
                        "tagName": "PowerACOut",
                        "value": 455.0804
                "deviceModel": [
                        "deviceClass": "com.kiwigrid.devices.inverter.Inverter"
                        "deviceClass": "com.kiwigrid.devices.solarwatt.MyReserveInverter"
                "tagValues": {
                    "DatePowerConsumptionForecastStart": {
                        "tagName": "DatePowerConsumptionForecastStart",
                        "guid": "31cea01c-8489-4a63-b58f-6d20c193728e",
                        "value": 1698054300000
                    "PowerOut": {
                        "value": 16
                    "PowerBuffered": {
                        "tagName": "PowerBuffered",
                        "tagName": "PowerConsumedFromGrid",
                        "value": 0
                    "PowerConsumedFromProducers": {
                        "tagName": "PowerConsumedFromProducers",
                        "value": 320.1086
                    "WorkOutFromStorage": {
                        "tagName": "WorkOutFromStorage",
                        "value": 23071.903247226728
                    "PowerOutFromStorage": {
                        "tagName": "PowerOutFromStorage",
                        "value": 0
                    "PowerConsumed": {
                        "tagName": "PowerConsumed",
                        "value": 320.1086
                    "PowerIn": {
                        "tagName": "PowerIn",
                        "value": 0
                    "PowerProduced": {
                        "tagName": "PowerProduced",
                        "value": 455.0804
                    "WorkConsumedFromGrid": {
                        "tagName": "WorkConsumedFromGrid",
                        "value": 7804835.357727677
                    "WorkConsumed": {
                        "tagName": "WorkConsumed",
                        "value": 1.688301133289597E7
                    "WorkBuffered": {
                        "tagName": "WorkBuffered",
                        "value": 3949011.6485447367
                    "PowerBufferedFromProducers": {
                        "tagName": "PowerBufferedFromProducers",
                    "PowerConsumptionForecastNow": {
                        "tagName": "PowerConsumptionForecastNow",
                        "value": null
                    "WorkSelfSupplied": {
                        "tagName": "WorkSelfSupplied",
                        "value": 9078175.975168308
                    "WorkConsumedFromStorage": {
                        "tagName": "WorkConsumedFromStorage",
                        "value": 3506157.781874271
                    "PowerConsumedFromStorage": {
                        "tagName": "PowerConsumedFromStorage",
                        "value": 0
                    "WorkOut": {
                        "tagName": "WorkOut",
                        "value": 1.5980751716239212E7
                    "PowerOutFromProducers": {
                        "tagName": "PowerOutFromProducers",
                        "value": 16.000000000000014
                    "PowerSelfSupplied": {
                        "tagName": "PowerSelfSupplied",
                        "value": 320.1086
                    "WorkBufferedFromGrid": {
                        "tagName": "WorkBufferedFromGrid",
                        "value": 125922.30329505456
                    "WorkOutFromProducers": {
                        "tagName": "WorkOutFromProducers",
                        "value": 1.5821395509547807E7
                    "PowerBufferedFromGrid": {
                        "tagName": "PowerBufferedFromGrid",
                        "value": 0
                    "WorkProduced": {
                        "tagName": "WorkProduced",
                        "value": 2.5216503048092782E7
                    "PowerSelfConsumed": {
                        "tagName": "PowerSelfConsumed",
                        "value": 439.0804
                "deviceModel": [
                        "deviceClass": "com.kiwigrid.lib.device.Device"
                        "deviceClass": "com.kiwigrid.devices.location.Location"
                "tagValues": {
                    "IdModelCode": {
                        "guid": "urn:sunspec:fronius:inverter:30355065",
                        "value": "Symo 10.0-3-M"
                    "PowerACOut": {
                        "value": 324
                    "WorkACOut": {
                        "value": 2.9161991248472214E7
                "deviceModel": [
                        "deviceClass": "com.kiwigrid.devices.sunspec.SunSpecInverter"
I my try was first something like (in restful.yaml that I import to config)
 - resource: http://192.168.1.13/rest/kiwigrid/wizard/devices
   scan_interval: 120
     - name: "energymanager_erzeugung_pv"
       icon: mdi:solar-power-variant
       value_template: "{{ value_json.result.items[8].tagValues.PowerProduced.value | round(0)}}"
       state_class: measurement
       unit_of_measurement: "W"
       device_class: power
     - name: "energymanager_direktverbrauch"
       icon: mdi:home-lightning-bolt-outline
       value_template: "{{ value_json.result.items[8].tagValues.PowerConsumed.value | round(0)}}"
       device_class: power
However, it seems that the device generates the result.items[]. list in a random order.
The interesting keys / values are:
“PowerProduced” , .result.items[8].tagValues.PowerProduced.value,
“PowerConsumed”, .result.items[8].tagValues.PowerConsumed.value,
“PowerOut”, .result.items[8].tagValues.PowerOut.value,
“PowerConsumedFromGrid”, .result.items[8].tagValues.PowerConsumedFromGrid.value,
“PowerBuffered”, .result.items[8].tagValues.PowerBuffered.value,
“PowerConsumedFromStorage”, .result.items[8].tagValues.PowerConsumedFromStorage.value,
“StateOfCharge”, .result.items[5].tagValues.StateOfCharge.value,
“ModeConverter”, .result.items[5].tagValues.ModeConverter.value’
I was thinking about something similar to the “brute force for loop” but doing it only once. (Since I need to create more entities with the single REST call)
So first iterate overItems[] and store all keys / values only once after the rest call and than just get the needed key in the sensor
(but I can’t get this to work)
{% set all_items = {} %}
{% for item in value_json.result['items'] %}
  {% for tag in item.tagValues  %}
    {# all_items[tag] = item.tagValues.[tag].value #}
    {{ tag }} ':' {{ item.tagValues.[tag] }}
  {% endfor %}
{% endfor %}
value_template: "{{ all_items['PowerConsumed']}}"
I need to study the selectattr('PowerConsumedFromGrid','defined') samples
Just to mention, in jq works :
jq -c '(
"PowerProduced", .result.items[].tagValues.PowerProduced.value,
"PowerConsumed", .result.items[].tagValues.PowerConsumed.value
) | select(.!=null)'
       value_template: "{{ (value_json['result']['items']|selectattr('tagValues.PowerConsumed','defined')|list|first)['tagValues']['PowerConsumed']['value']|round(0) }}"
       device_class: power
…and so on for the others. Just replace the two key names in each template. Same thing spaced for better readability:
       value_template: >
             |list|first)
            ['tagValues']['PowerConsumed']['value'] |round(0) }}
       device_class: power
