Restore a number onpower up
Hi I have the simplest bit of code running on my ESP8266 board and at one point I defined a number to use elsewhere, I would like it to be restored at power up. I used the restore_value: true but it just seems to start at its min value the code looks like. Am I missing something?
Mark
number:
    optimistic: true
    min_value: 0
    max_value: 150
    step: 1
    optimistic: true
    min_value: 20
    max_value: 50
    step: 1
    restore_value: true
You may also need to include the Core item: esp8266_restore_from_flash in order for restore_value to work.
Did I mention Im not very good :upside_down_face: ? I just tried esp8266_restore_from_flash in the header but I get a compiler error, Error: Unknown board ID esp01_1m esp8266_restore_from_flash
Have I put it in the wrong place?
esphome:
esp8266:
board: esp01_1m
Enable logging
logger:
Enable Home Assistant API
api:
Yes, most likely.
I believe it goes under ā€œESPHomeā€, but if you search it in the docs Iā€™m sure thereā€™s an example in there.
Youā€™ll also need to include the ā€˜: trueā€™ after the tag, to make it be valid. See the examples.
Thank you
Once I got the syntax correct it started working
This is the header part of the code
esphome:
   platform: esp8266
   board: esp01_1m
   esp8266_restore_from_flash : true
It seems to me that now you only accept it in this form
