I let it do it things over night, and was able to reconnect to the ‘new’ server IP. But with no indication of progress so I was flying blind. But it did not appear to be doing anything. I rebooted the pi via HA GUI, and once back up started the backup restore again. After two hours, the restore appears to have errors based on the logs. I’m having trouble determining a cause
2026-04-19 09:25:21.131 INFO (MainThread) [supervisor.docker.manager] Cleaning homeassistant application
2026-04-19 10:27:45.786 ERROR (MainThread) [supervisor.jobs] Unhandled exception: Unexpected failure
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 299, in wrapper
return await method(obj, *args, **kwargs)
File "/usr/src/supervisor/supervisor/homeassistant/module.py", line 546, in restore
data = await self.sys_run_in_executor(_restore_home_assistant)
File "/usr/local/lib/python3.14/concurrent/futures/thread.py", line 86, in run
result = ctx.run(self.task)
File "/usr/local/lib/python3.14/concurrent/futures/thread.py", line 73, in run
return fn(*args, **kwargs)
File "/usr/src/supervisor/supervisor/homeassistant/module.py", line 493, in _restore_home_assistant
backup.extractall(
path=temp_path,
filter="tar",
File "/usr/local/lib/python3.14/tarfile.py", line 2418, in extractall
self._extract_one(tarinfo, path, set_attrs=not tarinfo.isdir(),
numeric_owner=numeric_owner,
filter_function=filter_function)
File "/usr/local/lib/python3.14/tarfile.py", line 2521, in _extract_one
self._extract_member(tarinfo, os.path.join(path, tarinfo.name),
set_attrs=set_attrs,
filter_function=filter_function,
extraction_root=path)
File "/usr/local/lib/python3.14/tarfile.py", line 2610, in _extract_member
self.makefile(tarinfo, targetpath)
File "/usr/local/lib/python3.14/tarfile.py", line 2667, in makefile
copyfileobj(source, target, tarinfo.size, ReadError, bufsize)
File "/usr/local/lib/python3.14/tarfile.py", line 249, in copyfileobj
buf = src.read(bufsize)
File "/usr/local/lib/python3.14/tarfile.py", line 536, in read
buf = self._read(size)
File "/usr/local/lib/python3.14/tarfile.py", line 554, in _read
buf = self.fileobj.read(self.bufsize)
File "/usr/local/lib/python3.14/site-packages/securetar/__init__.py", line 306, in read
self._fill_buffer(size)
File "/usr/local/lib/python3.14/site-packages/securetar/__init__.py", line 622, in _fill_buffer
plaintext, tag = nss.crypto_secretstream_xchacha20poly1305_pull(
self._state, encrypted
File "/usr/local/lib/python3.14/site-packages/nacl/bindings/crypto_secretstream.py", line 329, in crypto_secretstream_xchacha20poly1305_pull
ensure(rc == 0, "Unexpected failure", raising=exc.RuntimeError)
File "/usr/local/lib/python3.14/site-packages/nacl/exceptions.py", line 88, in ensure
raise raising(*args)
nacl.exceptions.RuntimeError: Unexpected failure
2026-04-19 10:27:46.053 ERROR (MainThread) [supervisor.backups.manager] Restore 9b0fb756 error
backup.extractall(
path=temp_path,
filter="tar",
File "/usr/src/supervisor/supervisor/backups/manager.py", line 733, in _do_restore
task_hass = await backup.restore_homeassistant()
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 307, in wrapper
raise err
File "/usr/src/supervisor/supervisor/backups/backup.py", line 951, in restore_homeassistant
await self.sys_homeassistant.restore(
homeassistant_file, self.homeassistant_exclude_database
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 312, in wrapper
raise JobException() from err
supervisor.exceptions.JobException
2026-04-19 10:27:46.069 INFO (MainThread) [supervisor.backups.manager] Restore 9b0fb756 starting stage await_home_assistant_restart
2026-04-19 10:27:46.104 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
2026-04-19 10:27:46.896 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/raspberrypi4-64-homeassistant with version 2026.4.3
2026-04-19 10:27:46.897 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
2026-04-19 10:28:11.598 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state freeze
2026-04-19 10:28:11.599 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2026-04-19 10:28:11.985 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2026-04-19 10:28:11.996 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='NOT_RUNNING', offline_db_migration=False)
2026-04-19 10:28:22.088 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to APIState(core_state='RUNNING', offline_db_migration=False)
2026-04-19 10:28:22.088 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
2026-04-19 10:28:22.184 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-3591' coro=<BackupManager.do_restore_partial() done, defined at /usr/src/supervisor/supervisor/jobs/decorator.py:245> exception=BackupError('Restore 9b0fb756 error, see supervisor logs')>
backup.extractall(
path=temp_path,
filter="tar",
raise err
raise err
File "/usr/src/supervisor/supervisor/backups/manager.py", line 950, in do_restore_partial
success = await self._do_restore(
...<6 lines>...
File "/usr/src/supervisor/supervisor/backups/manager.py", line 766, in _do_restore
raise BackupError(
f"Restore {backup.slug} error, see supervisor logs"
) from err
supervisor.exceptions.BackupError: Restore 9b0fb756 error, see supervisor logs
