Hello, I did a HomeAssistant installation on a Synolgoy Diskstation using Docker. Previously, HomeAssistant ran on a Raspi. I made a backup of the Raspi HomeAssistant instance and now want to restore it to the Docker instance. So far I haven’t managed to do that, neither is the backup displayed when I copy it to “Backup” in Config, nor does copying the entire Config folder to the new Docker instance work. Does anyone have an idea how I can do a restore here?
Would you mind sharing your docker compose file (or maybe screenshots of the Docker setup for the HA instance from the Synology)? I’m wondering if you have the config for the config mount correct, as that is a highly likely reason the Docker HA instance is not seeing your config.
Yes Sure, i do IT tommorow
It’s a little unusual to map the config directory to something in /docker
as that directory is usually not visible as a share, at least not by default. For instance, I have /config
mapped to dvr_media/configs/home_assistant/config
. I’m also not sure about that leading slash for first part of the volume. My German is a little rusty though.
