Restore non-booting install from SD card only
Hi!
Hope this is the best place.
I started using home-assistant a couple weeks ago and everything was going mostly fine. Until I moved the Pi it was running on and now it won’t boot. Not blaming home assistant in any way, the SD card was probably going bad. My problem is that I would really like if I didn’t have to redo everything from scratch.
Since I was configuring it and adding new devices, I have 0 backups I’m aware of.
I can mount the SD card to a linux host, and I was wondering if there is any way to do a backup / restore this way.
NB: Most of my things are z-wave devices or integrations like nest/hue.
This is what I’m trying to recover without having to manually reset all the z-wave devices because that’s a PAIN.
Thanks in advance.
If you can read the SD card, you can grab the entire configuration directory and copy to a new one. You’ll then just need to reinstall the actual add-ons.
