Apart from the bootup process, the denonavr is sometimes giving warnings during normal usage (reason: i disabled polling, all data that is relevant to me is coming from telnet local push). For these sporadic warnings, my original question is still relevant. It would be great to know the component name of the denon integration.
Thank you. I’ve solved my problem in a different way, so that the warning won’t be there in the first place. The warning happens after connecting the AVR to mains power. I now disable the denonavr integration via Spooky before disconnecting the AVR from power (by using a simple automation), and enabling the integration a while after restoring to power (power savings → eco-friendly).
Some more background: i wanted the denon avr integration to be fully local push, instead of the current behaviour in which it is doing both local push + local polling. I achieved this by a) disabling local push via the Spooky integration and b) enabling “Use telnet connection”.
The advantage of this setup is 100% local push (no pull), so less cpu utlization and less network traffic. I try to keep my system as lean as possible.
