RetroArch for Home Assistant
I built a custom integration that lets Home Assistant talk to RetroArch over its built-in UDP Network Control Interface. You get the running game and system, a media
player, a pile of control buttons, optimistic switches, live in-game RAM values, box art, and LAN auto-discovery — all local, no cloud, no account.
What it does
Media player — the running game as the media title, the system/core as the app name, with play/pause/stop and volume.
Box art — pulls the game's cover from the libretro thumbnail server (with an override in the options if it guesses the system wrong).
Sensors — status, current game, system/core, content CRC32, RetroArch version, plus video/audio/menu drivers.
Configurable RAM sensors — read live in-game values (lives, score, HP…) by memory address.
Binary sensors — playing, paused, content loaded.
34 buttons — reset, save/load state, state slot ±, screenshot, fast forward, rewind, slow motion, disk eject/next/prev, shaders, cheats, AI service, quit, and
more.
Switches — fast forward, slow motion, mute, fullscreen, pause (optimistic, since the protocol only exposes toggles).
Services — send any raw command, read/write core memory, show an on-screen message, load a state slot / shader / core.
Auto-discovery — finds RetroArch on your LAN with a UDP broadcast probe; manual host/port entry as a fallback.
Translations — English, Português (Brasil), Español.
Local polling — talks straight to RetroArch on your network.
Requirements
Enable RetroArch's network commands — Settings → Network → Network Commands (port 55355), or in retroarch.cfg:
network_cmd_enable = "true"
network_cmd_port = "55355"
Then restart RetroArch. Auto-discovery uses a LAN broadcast, so it works best when HA and RetroArch are on the same subnet.
Install (HACS)
It's a custom repository for now:
- HACS → ⋮ (top right) → Custom repositories, add
https://github.com/hudsonbrendon/ha-retroarchas an Integration. - Install RetroArch and restart Home Assistant.
- Settings → Devices & Services → Add Integration → RetroArch — let it scan the network, or type the host/port.
You can change the host/port later via Configure (no need to remove the integration), and add RAM sensors / tweak box art there too.
Hope it's handy for other retro folks running RetroArch next to Home Assistant. ![]()
