Just moved over from Hassbian to Hassio and everything is working great apart from a shell command that I use for changing channels via IR to my satellite box - the code works ok on Hassbian. Just wondered where it is failing.
Here is the error
Error running command:
mosquitto_pub -u myusername -P mypw -t home/commands/IR_NEC/IRBITS_32/RPT_4 -m “573503” && mosquitto_pub -u myusername -P mypw -t home/commands/IR_NEC/IRBITS_32/RPT_4 -m “536783” && mosquitto_pub -u myusername -P mypw -t home/commands/IR_NEC/IRBITS_32/RPT_4 -m “573503”`, return code: 127
/usr/lib/python3.6/site-packages/homeassistant/components/shell_command.py (ERROR)`
And here is my Mosquitto add on settings
"plain": true,
"ssl": false,
"anonymous": false,
"logins": [
"username": "myusername",
"password": "mypw"
"customize": {
"active": false,
"folder": "mosquitto"
"certfile": "fullchain.pem",
"keyfile": "privkey.pem"
here is an extract from the shell.yaml
##### Humax #####
wemos_bbc1 : !secret bbc1
wemos_bbc2 : !secret bbc2
wemos_itv : !secret itv
and finally the command from the secrets folder
bbc1: mosquitto_pub -u myusername -P mypw -t home/commands/IR_NEC/IRBITS_32/RPT_4 -m "573503" && mosquitto_pub -u myusername -P mypw -t home/commands/IR_NEC/IRBITS_32/RPT_4 -m "536783" && mosquitto_pub -u myusername -P mypw -t home/commands/IR_NEC/IRBITS_32/RPT_4 -m "573503"
If I run mosquitto_pub -u myusername -P mypw -t home/commands/IR_NEC/IRBITS_32/RPT_4
with a payload of 573503
from within HA Dev MQTT ir runs the command fine.
Any ideas how I can get this command to run ? Thanks
