At the moment, my automations contain a lot of repeated code which could be eliminated. Automation needs a template function.
Example: I am using automation to make the blinds of my windows close when the windows are closed after sunset. Currently it looks like this:
- alias: 'Niklas: Rolladen links schließen wenn Fenster schließen'
platform: state
entity_id: binary_sensor.niklas_fenster_links_state
to: 'off'
for:
seconds: 5
condition:
condition: numeric_state
entity_id: sun.sun
value_template: '{{ state.attributes.elevation }}'
below: -4.75
service: cover.close_cover
entity_id: cover.niklas_rolladen_links
platform: state
entity_id: binary_sensor.niklas_fenster_rechts_state
to: 'off'
for:
seconds: 5
condition:
entity_id: sun.sun
below: -4.75
entity_id: cover.niklas_rolladen_rechts
Both automations are almost exactly the same except for the entity ids. This automation could be defined as a template automation, the entity ids would be passed on as parameters.
There are even more complex examples than this one which would make this a very useful feature. Not sure if this is easy to implement, though.
