Reverse engineering the ELEGRP PQR21
I’m fairly new to ESPHome and Home Assistant, but so far I’ve been having way too much fun with this stuff. I hope this helps someone. Mods feel free to move it if this is in the wrong place.
I recently picked up a couple of ELEGRP PQR21 and with the help of Claude, was able to get it working with ESPHome.
A couple of notes: Tuya-cloudcutter hasn’t been able to crack any tuya device I’ve tried. I think unfortunately the firmware has been patched to the point where this is not a reliable option.
That being said, as I have been flashing all kinds of stuff lately, I picked up one of these BDM frames from Amazon for about $35 and now no soldering required.
*Backup and flashing were easy. ltchiptool running when the CBU booted immediately started reading / writing.
Claude assisted with generating a template based on other ELEGRP Dimmers:
This config includes:
  • CBU board type and UART settings for the TuyaMCU link at 9600 baud
  • Dimmable socket on DP 1 (on/off) and DP 2 (brightness), with 10-1000 scale
  • Non-dimmable socket on DP 7
  • Dimmer Level percentage slider for brightness control
  • SNTP time source for the MCU to answer its time queries
  • Web UI, restart button, and standard sensors
I’ve added TODO comments where users need to insert their specific settings like device name, API key, OTA, and Wi-Fi credentials.
esphome:
  # TODO: Uncomment and change to a unique name
  # friendly_name: "ELEGRP PQR21"
bk72xx:
  board: cbu
# Serial logging off: TX1/RX1 are used by the TuyaMCU.
# Logs are still visible in the web interface and ESPHome dashboard.
logger:
  baud_rate: 0
  level: DEBUG
# TODO: Uncomment and set up your ESPHome API and OTA settings
#api:
#  encryption:
#    key: ""
#ota:
#  - platform: esphome
# TODO: Uncomment and set up your Wi-Fi settings
#wifi:
#  ssid: !secret wifi_ssid
#  password: !secret wifi_password
#  ap:
#    ssid: "ELEGRP PQR21 Fallback Hotspot"
#    password: ""
captive_portal:
web_server:
  port: 80
  version: 3
# Link to the TuyaMCU
uart:
  rx_pin: RX1
  tx_pin: TX1
  baud_rate: 9600
# The MCU asks for the time; this answers it
time:
  - platform: sntp
tuya:
  time_id: sntp_time
# Dimmable socket on DP 1 (on/off) and DP 2 (brightness)
light:
  - platform: tuya
    switch_datapoint: 1
    dimmer_datapoint: 2
    min_value: 10
    max_value: 1000
# Non-dimmable socket on DP 7
switch:
  - platform: tuya
    switch_datapoint: 7
# Percentage slider for dimmer brightness (MCU scale 10-1000 = 1-100%)
# Sets brightness directly; does not turn the socket on by itself
number:
  - platform: tuya
    number_datapoint: 2
    min_value: 1
    max_value: 100
    step: 1
    multiply: 10
    unit_of_measurement: "%"
button:
  - platform: restart
  - platform: wifi_signal
    update_interval: 60s
  - platform: uptime
text_sensor:
  - platform: wifi_info
    ip_address:
    ssid:
