gatorback
(Raymond C)
November 24, 2023, 5:41am
1
CONTEXT
AMD / 12GB / 1TB SSD
Docker HA
WAN ports forwarded for web access: www.mydomain.com
GOAL:
QUESTIONS:
I understand that Traefic or NGINX can serve as the reverse proxy:
Is it best practice / Does it make sense to have the reverse proxy in its own container?
What questions must be asked / answered to decide if Traefic or NGINX is the better choice
Tinkerer
(aka DubhAd on GitHub)
November 24, 2023, 10:21am
2
gatorback:
Yes
gatorback:
Do you want a modern proxy that handles SSL for you (Traefik) or do you want to manage SSL elsewhere (NGINX).
gatorback
(Raymond C)
November 24, 2023, 3:57pm
3
Good to hear from you Tinkerer. Thank you for simplifying the decisions. Do you have any “lessons learned” regarding Traefik implemented in containers?
Tinkerer
November 24, 2023, 4:12pm
4
Honestly, I just followed the docs. You’ll have to tell it the port to use, something like this added to the compose entry:
labels:
- "traefik.enable=true"
- "traefik.http.routers.homeassistant.rule=Host(`ha.ceard.tech`)"
- "traefik.http.routers.homeassistant.tls=true"
- "traefik.http.routers.homeassistant.tls.certresolver=zerossl"
- "traefik.http.routers.homeassistant.entrypoints=websecure"
- "traefik.http.services.homeassistant.loadBalancer.server.port=8123"
I happen to run HA remote from Traefik, so my setup is subtly different, but Traefik is well documented and has an active forum (plus many people have written great guides).
