Reverse proxy with NGINX using a subdomain
Tags: #<Tag:0x00007f73996b4860> #<Tag:0x00007f73996b4748>
:warning: This guide has been migrated from our website and might be outdated. Feel free to edit this guide to update it, and to remove this message after that.
This example demonstrates how you can configure NGINX to act as a proxy for Home Assistant.
This is useful if you want to have:
  • a subdomain redirecting to your Home Assistant instance
  • several subdomains for several instances
  • HTTPS redirection
Subdomain
So you already have a working NGINX server available at example.org. Your Home Assistant is correctly working on this webserver and available at http://localhost:8123
To be able to access to your Home Assistant instance by using https://home.example.org, create file /etc/nginx/sites-enabled/homeassistant (or symlink via /etc/nginx/sites-available) and add the following:
server {
    listen       443 ssl;
    server_name  home.example.org;
    ssl on;
    ssl_certificate /etc/nginx/ssl/home.example.org/home.example.org-bundle.crt;
    ssl_certificate_key /etc/nginx/ssl/home.example.org/home.example.org.key;
    ssl_prefer_server_ciphers on;
    location / {
        proxy_pass http://localhost:8123;
        proxy_set_header Host $host;
        proxy_http_version 1.1;
        proxy_set_header Upgrade $http_upgrade;
        proxy_set_header Connection "upgrade";
    location /api/websocket {
        proxy_pass http://localhost:8123/api/websocket;
If you don’t want HTTPS, you can change listen 443 ssl to listen 80 or better, consider redirecting all HTTP to HTTPS. See further down.
Multiple Instance
You already have Home Assistant running on http://localhost:8123 and available at home.example.org as describe before. The configuration file for this Home Assistant is available in /home/alice/.homeassistant/configuration.yaml.
You want another instance available at https://countryside.example.org
You can either:
  • Create a new user, bob, to hold the configuration file in /home/bob/.homeassistant/configuration.yaml and run Home Assistant as this new user
  • Create another configuration directory in /home/alice/.homeassistant2/configuration.yaml and run Home Assistant using hass --config /home/alice/.homeassistant2/
In both solution, change port number used by modifying configuration.yaml file.
http:
  server_port: 8124
Start Home Assistant: Now, you have another instance running on http://localhost:8124
To access this instance by using https://countryside.example.org create the file /etc/nginx/sites-enabled/countryside.example.org (or symlink via /etc/nginx/sites-available) and add the following:
server {
    listen       443 ssl;
    server_name  countryside.example.org;
    ssl on;
    ssl_certificate /etc/nginx/ssl/countryside.example.org/countryside.example.org-bundle.crt;
    ssl_certificate_key /etc/nginx/ssl/countryside.example.org/countryside.example.org.key;
    location / {
        proxy_pass http://localhost:8124;
        proxy_pass http://localhost:8124/api/websocket;
HTTP to HTTPS redirection
Add to your /etc/nginx/sites-enabled/default
server {
    listen       80 default_server;
    server_name  example.tld;
    return 301 https://$host$request_uri;
