I accidentally installed a beta OS update taking me from HA OS 9.5 to 10.0.rc1
Unfortunately now the MQTT broker and a few other addons don’t run
I realise the easiest solution would have been the obvious - don’t accidentally install a release candidate…however restoring a full backup hasn’t reverted the OS update. Is there anything else I can do?
olesj
(Ole Jakobsen)
March 25, 2023, 9:19am
2
I belive there is a way to rollback os, im in the same situation no zigbee working.
I’m tryin to figurer it out what last os version was, and the command line is .
This seems to be the issue:
opened 12:47PM - 06 Mar 23 UTC
### Describe the issue you are experiencing
When I launch the mosquitto broke… r it complains about port 1884, even if I change the port in the configuration, the issue remains. So I think the port conflict should be inside the container.
### What type of installation are you running?
Home Assistant Supervised
### Which operating system are you running on?
Other (e.g., Raspbian/Raspberry Pi OS/Fedora)
### Which add-on are you reporting an issue with?
Mosquitto broker
### What is the version of the add-on?
6.1.3
### Steps to reproduce the issue
1. Start the addon with any configuration
### System Health information
## System Information
version | core-2023.3.1
installation_type | Home Assistant Supervised
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.10.10
os_name | Linux
os_version | 6.2.2-arch1-1
arch | x86_64
timezone | America/Sao_Paulo
config_dir | /config
<details><summary>Home Assistant Community Store</summary>
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
GitHub API Calls Remaining | 4962
Installed Version | 1.31.0
Stage | running
Available Repositories | 1242
Downloaded Repositories | 5
</details>
<details><summary>Home Assistant Cloud</summary>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Arch Linux
update_channel | stable
supervisor_version | supervisor-2023.01.1
agent_version | 1.4.1
docker_version | 23.0.1
disk_total | 111.3 GB
disk_used | 50.5 GB
healthy | true
supported | failed to load: Unsupported
supervisor_api | ok
version_api | ok
installed_addons | Duck DNS (1.15.0), Home Assistant Google Drive Backup (0.110.1), Studio Code Server (5.5.3), Mosquitto broker (6.1.3), Terminal & SSH (9.6.1), SQLite Web (3.7.0), Zigbee2MQTT (1.30.2-1), Node-RED (14.0.3), NGINX Home Assistant SSL proxy (3.2.0), UniFi Network Application (2.5.0)
</details>
<details><summary>Dashboards</summary>
dashboards | 1
resources | 0
views | 4
mode | storage
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | 25 de fevereiro de 2023 às 19:43
current_recorder_run | 6 de março de 2023 às 09:39
estimated_db_size | 356.35 MiB
database_engine | sqlite
database_version | 3.38.5
</details>
<details><summary>Sonoff</summary>
version | 3.4.0 (5406fa7)
cloud_online | 27 / 31
local_online | 27 / 27
</details>
<details><summary>Spotify</summary>
api_endpoint_reachable | ok
</details>
### Anything in the Supervisor logs that might be useful for us?
```txt
23-03-06 09:43:13 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning addon_core_mosquitto application
23-03-06 09:43:13 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-mosquitto with version 6.1.3
23-03-06 09:43:20 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Mosquitto broker is stopped, restarting...
23-03-06 09:43:20 INFO (SyncWorker_4) [supervisor.docker.interface] Cleaning addon_core_mosquitto application
23-03-06 09:43:21 INFO (SyncWorker_5) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-mosquitto with version 6.1.3
23-03-06 09:43:27 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Mosquitto broker is stopped, restarting...
23-03-06 09:43:27 INFO (SyncWorker_6) [supervisor.docker.interface] Cleaning addon_core_mosquitto application
23-03-06 09:43:27 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-mosquitto with version 6.1.3
23-03-06 09:43:34 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Mosquitto broker is stopped, restarting...
23-03-06 09:43:34 INFO (SyncWorker_7) [supervisor.docker.interface] Cleaning addon_core_mosquitto application
23-03-06 09:43:34 INFO (SyncWorker_4) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-mosquitto with version 6.1.3
23-03-06 09:43:41 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Mosquitto broker is stopped, restarting...
23-03-06 09:43:41 INFO (SyncWorker_2) [supervisor.docker.interface] Cleaning addon_core_mosquitto application
23-03-06 09:43:41 INFO (SyncWorker_6) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-mosquitto with version 6.1.3
23-03-06 09:43:47 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Mosquitto broker is stopped, restarting...
23-03-06 09:43:47 INFO (SyncWorker_7) [supervisor.docker.interface] Cleaning addon_core_mosquitto application
23-03-06 09:43:48 INFO (SyncWorker_0) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-mosquitto with version 6.1.3
23-03-06 09:43:54 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Mosquitto broker is stopped, restarting...
23-03-06 09:43:54 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning addon_core_mosquitto application
23-03-06 09:43:55 INFO (SyncWorker_4) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-mosquitto with version 6.1.3
23-03-06 09:44:01 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Mosquitto broker is stopped, restarting...
23-03-06 09:44:01 INFO (SyncWorker_7) [supervisor.docker.interface] Cleaning addon_core_mosquitto application
23-03-06 09:44:01 INFO (SyncWorker_3) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-mosquitto with version 6.1.3
23-03-06 09:44:07 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Mosquitto broker is stopped, restarting...
### Anything in the add-on logs that might be useful for us?
```txt
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[09:29:48] INFO: Setting up user kodi
[09:29:48] INFO: Certificates found: SSL is available
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
s6-rc: info: service legacy-services successfully started
[09:29:49] INFO: Starting NGINX for authentication handling...
[09:29:49] INFO: Starting mosquitto MQTT broker...
2023-03-06 09:29:49: Warning: Mosquitto should not be run as root/administrator.
2023-03-06 09:29:49: mosquitto version 2.0.11 starting
2023-03-06 09:29:49: Config loaded from /etc/mosquitto/mosquitto.conf.
2023-03-06 09:29:49: Loading plugin: /usr/share/mosquitto/go-auth.so
2023-03-06 09:29:49: ├── Username/password checking enabled.
2023-03-06 09:29:49: ├── TLS-PSK checking enabled.
2023-03-06 09:29:49: └── Extended authentication not enabled.
2023-03-06 09:29:49: Opening ipv4 listen socket on port 1883.
2023-03-06 09:29:49: Opening ipv6 listen socket on port 1883.
2023-03-06 09:29:49: Opening websockets listen socket on port 1884.
2023-03-06 09:29:49: Error: Unable to create websockets listener on port 1884.
[12:29:49] WARNING: Halt add-on
s6-rc: info: service legacy-services: stopping
[12:29:49] INFO: Service restart after closing
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
### Additional information
_No response_
Latest post has the same problem as me, and in passing mentions that a rollback is both possible and effective…just not sure how to achieve it
Ahah!
Someone (maybe @olesj ) asked the question directly on the git thread - and the suggestion worked!
Cheers all!
olesj
(Ole Jakobsen)
March 25, 2023, 1:50pm
5
Thanks, I think that’s me too os rollback works fine.
I ran this line " ha os update --version 9.5 " in the terminal window .
