In a month we will have a new heating system in our bathroom.
It works with a wireless thermostat that communicates over RF 433MHz to the Infrared heating panel.
I was wondering if I could capture and reuse the same signal to control the heating panel without using the thermostat?
Anybody an idea which device I could buy or create myself?
I editted my post about the type.
It’s another room than you thought
Thanks for the suggestions, I’m gonna have a look at the different options.
I see with the ESPHome you can only use the existing commands as I don’t find the device so I would need to capture the signal first before I can use it.
Same issue with the openmqttgateway.
And same for the RFXCOM as well.
I have no idea how I can capture that and like export the RAW data, if I could get the raw data than I could use the ESPHome option as I saw that there is a raw command.
yeah it’s probably just turn on and off, I have no manual of it, so with the ESPHome I should get a RF receiver module to capture it and than use the transmitter to replicate it.
