RF Bridge Tasmota Homeassistant Switch Unavailable
Hi there
I hope someone can help me as this is driving me mad.
I have a sonoff rf bridge which I managed to install tasmota with the portisch firmware. I have sniffed the rf codes that I am after and have been able to send them via mqtt. I then added it on HA by creating an MQTT switch in the following manner:
    - unique_id: projector
      command_topic: "cmnd/rfbridge/rfraw"
      state_topic: "stat/rfbridge/rfraw"
      availability_topic: "tele/rfbridge/LWT"
      payload_on: "AAB0210308024400AA16B22819090818181908190819081909090819081818190819090955"
      payload_off: "AAB0210308024400AA16BC2819090818181908190819081909090819081818190908190955"
      payload_available: "Online"
      payload_not_available: "Offline"
      optimistic: true
Everything worked well until I added another switch and now both the first switch shows unavailable while the second says unavailable and entity is no longer provided by the mqtt intergration. The second switch config is below:
    - unique_id: projector_stop
      name: "Projector Screen Stop"
      payload_on: "AAB0210308025800A016762819090818181908190819081909090819081818181909090955"
      optimistic: true
I am not sure what I am doing wrong and I even went to remove all the “retain” messages on my mqtt broker but nothing helped.
Can someone please help me with this? thanks.
Show your whole configuration. I suspect you have 2 times
switch:
in which case only the second switch will be used.
nope I dont, here is my config:
############# MQTT ###################
mqtt:
  switch:
    - unique_id: trv_1
      state_topic: "zigbee2mqtt/tuya/set/system_mode"
      command_topic: "zigbee2mqtt/tuya/set/system_mode"
      payload_on: "heat"
      payload_off: "off"
      state_on: "heat"
      state_off: "off"
      retain: true
    - unique_id: trv_2
      name: "5th Bedroom TRV"
      state_topic: "zigbee2mqtt/tuya2/set/system_mode"
      command_topic: "zigbee2mqtt/tuya2/set/system_mode"
      payload_on: "heat"
      payload_off: "off"
      state_on: "heat"
      state_off: "off"
      retain: true
    - unique_id: trv_3
      name: "Master Bedroom TRV"
      state_topic: "zigbee2mqtt/tuya3/set/system_mode"
      command_topic: "zigbee2mqtt/tuya3/set/system_mode"
      payload_on: "heat"
      payload_off: "off"
      state_on: "heat"
      state_off: "off"
      retain: true
    - unique_id: trv_4
      name: "Livingroom TRV Near Garden"
      state_topic: "zigbee2mqtt/tuya4/set/system_mode"
      command_topic: "zigbee2mqtt/tuya4/set/system_mode"
      payload_on: "heat"
      payload_off: "off"
      state_on: "heat"
      state_off: "off"
      retain: true
      optimistic: true
#      retain: false
      optimistic: true
See if some of the switches have been orphaned and readded with a _2 or similar.
blimey thats correct :slight_smile: thanks a lot.
why does it do that? orphaned and readded? can I get rid of the old ones which are orphaned?
Delete them in the entities list under Settings → Devices & Services → Entities tab.
Or if you are sure that those are the only orphaned ones, then install Spook and use the service: “Remove all orphaned entities”.
thanks alot god bless :slight_smile:
