RF Switch with Unitcode instead of decimal
Is there a way of transforming a given unitcode and systemcode used for https://github.com/r10r/rcswitch-pi to a decimal code, which is required by the Pi RF Switch?
I would like to move one of my installations to docker, where rc-switch is not available in my image. Therefore, I would like to migrate my command line switches to the Pi RF Switch component. If possible, I would like to transform my existing system- and unitcodes to the required decimal codes, which would safe me from sniffing all codes again. Is there a way to achieve this?
Thanks!
Specifically, I would like to transform a command like the following to be used with the Pi RF Switch:
sudo /opt/rcswitch-pi/send 11001 1 0
