RFlink Manually Add Commands and Devices
I bought a RFLink to attempt to add these 433.92 outlets with thermostat remotes (I have 3) to Home Assistant. I add the configuration, yet the PING PONG is not finding identifying devices. What I want to know if there is a way to do this manually. I was able to successfully teach on and off command with a Flipper Zero, so I know it is possible.
I believe I could create a custom switch devices, but teaching the devices the codes if where I am not certain where to begin.
These are my logs.
2023-05-29 10:30:50.810 DEBUG (MainThread) [rflink.protocol] received data: 20;88;PONG;
2023-05-29 10:30:50.811 DEBUG (MainThread) [rflink.protocol] got packet: 20;88;PONG;
2023-05-29 10:30:50.811 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'unknown', 'ping': 'pong'}type or paste code here
2023-05-30 14:04:16.512 WARNING (MainThread) [rflink.protocol] dropping invalid data: H=00;CMD=OFF;
2023-05-30 14:04:48.175 DEBUG (MainThread) [rflink.protocol] received data: 20;27;PONG;
