I’ve a RFLink integration, which can detect my small (433Mhz) remotes
The remote comes with 4 button of wich i want to use 2
(1 with an lock symbol and 1 with an unlocked symbol)
When i monitor the logger details is see the followoing information
For Button 1 (unlocked):
2020-08-17 13:46:55 DEBUG (MainThread) [rflink.protocol] received data: 20;06;TriState;
2020-08-17 13:46:55 DEBUG (MainThread) [rflink.protocol] received data: ID=XXYY51;SWITCH=0;CMD=O
2020-08-17 13:46:55 DEBUG (MainThread) [rflink.protocol] received data: FF;
2020-08-17 13:46:55 DEBUG (MainThread) [rflink.protocol] got packet: 20;06;TriState;ID=XXYY51;SWITCH=0;CMD=OFF;
2020-08-17 13:46:55 DEBUG (MainThread) [rflink.protocol] decoded packet: {‘node’: ‘gateway’, ‘protocol’: ‘tristate’, ‘id’: ‘XXYY51’, ‘switch’: ‘0’, ‘command’: ‘off’}
2020-08-17 13:46:55 DEBUG (MainThread) [rflink.protocol] got event: {‘id’: ‘tristate_XXYY51_0’, ‘command’: ‘off’}
2020-08-17 13:46:55 DEBUG (MainThread) [homeassistant.components.rflink] event of type command: {‘id’: ‘tristate_XXYY51_0’, ‘command’: ‘off’}
2020-08-17 13:46:55 DEBUG (MainThread) [homeassistant.components.rflink] entity_ids: [‘light.tristate_XXYY51_0’]
2020-08-17 13:46:55 DEBUG (MainThread) [homeassistant.components.rflink] passing event to light.tristate_XXYY51_0For Button2 (Locked):
2020-08-17 13:47:37 DEBUG (MainThread) [rflink.protocol] received data: 20;07;TriState;ID=XXYY5
2020-08-17 13:47:37 DEBUG (MainThread) [rflink.protocol] received data: 0;SWITCH=1;CMD=OFF;
2020-08-17 13:47:37 DEBUG (MainThread) [rflink.protocol] got packet: 20;07;TriState;ID=XXYY50;SWITCH=1;CMD=OFF;
2020-08-17 13:47:37 DEBUG (MainThread) [rflink.protocol] decoded packet: {‘node’: ‘gateway’, ‘protocol’: ‘tristate’, ‘id’: ‘XXYY50’, ‘switch’: ‘1’, ‘command’: ‘off’}
2020-08-17 13:47:37 DEBUG (MainThread) [rflink.protocol] got event: {‘id’: ‘tristate_XXYY50_1’, ‘command’: ‘off’}
2020-08-17 13:47:37 DEBUG (MainThread) [homeassistant.components.rflink] event of type command: {‘id’: ‘tristate_XXYY50_1’, ‘command’: ‘off’}
2020-08-17 13:47:37 DEBUG (MainThread) [homeassistant.components.rflink] entity_ids: [‘light.tristate_XXYY50_1’]
2020-08-17 13:47:37 DEBUG (MainThread) [homeassistant.components.rflink] passing event to light.tristate_XXYY50_
I want to have an automation working when i press button (unlocked) it switchws my alarm off and when i press the second button it switches my alarm on
(As shown by Average Automation - https://www.youtube.com/channel/UCMR_eJdL5P6SVJ2n0kTCjlg)
He uses an tasmoto intgration with differnt info.
The following code is to create a button
- platform: mqtt
state_topic: "tele/tasmota/RESULT"
value_template: '{{value_json.RfReceived.Data}}'
payload_on: '2C4528'
payload_off: '2C4524'
device_class: lock
I Understand that i need to change the platform and state_topic.
(but to what value for RFLink devices)
What wonders me the most is that my buttons are shown as light and the both produce an "Off"when pressed.
As listed in the “Developers tools/States” page:
