RFlink warning dropping invalid data
Hello people,
I have recently bought a nodo rflink 868mhz with an aruidno, every time i start my home asistant i get this warning: ‘WARNING (MainThread) [rflink.protocol] dropping invalid data: 20;01;MySensors=ON;’
This is my configuration:
rflink:
    port: /dev/ttyACM0
    wait_for_ack: true
logger:
  default: error
  logs:
    rflink: debug
    homeassistant.components.rflink: debug
What am i missing?
I think it is normal behavior.
I built such gateway by myself.
I have wait_for_ack: false, no such message and gateway works fine with 6 smoke detectors.
This message is part of the RFLink startup messaging and you don’t have to worry about it:
I have the same error and my Cresta temp sensor is not transmitting data anymore. When I reset the sensor is reads only once and then it stops. It worked for months but now it doesnt. I already bought a new sensor because I figured the other one broken. but the new one is doing the same as the old one.
It works again. Apparently a hard reboot was enough to fix it.
