RFXCOM Integration gives 500 Internal Server Error Server got itself in trouble
When Clicking configure in the RFXCOM integration I get:
Home assistant version: 2022.2.8
No problems with other integrations
No issues for me with same version. Running in a non-host ha docker (not: io). Did not need to manually add when adding --device /dev/ttyUSB0:/dev/ttyUSB0 to the docker run command
same problem here; solved bij install the integration again
