RFXCom on the new release 113
I installed the new release and as expected all devices with RFXCom doesnt work any more.
I declared devices (I have covers and curtains) in the configuration.yaml file as the documentation says:
`rfxtrx:
  device: /dev/ttyUSB0
  debug: true
  devices:
    # cover 1
    09190600C0342C210260:
      device_class: opening`
After restarting, if I got for all devices, ie curtains and cover) in enttities:
for example: cover.unknown_type_0x19_0x06_c0342c_43
Where can I declare the type to resolve the unknow type ?
I see now there are rssi value. What represent these values ? Is that the value when an remote control send the same code ?
I don’t find any detailled and may be example for more complet application. Is that exist ?
Many thanks for your help and best regards.
Thierry
The rssi is the signal strength from a device to the rfxcom (in dBm). It says something about the quality of the received signal, the higher the number the better.
