RfxCom with Kaku acd200
I’ve a question about the RFXCOM integration.
I’ve a KlikAanKlikUit ACD200 (dimmer) but it’s only showing in Home Assistant with the switch. I can make it like a “light” bit still no dimming there. I see that it’s possible with changing a bit, but I don’t see the referenced event codes mentioned in the documenatation.
Edit: The device Id which was set before the last Home Assistant update in the configuration.yaml was: “0710010044030050”
