RFXtrx binary sensor setup issue in hassio
Hi everyone,
just moved over to hassio on my raspberry pi 2. I have setup the RFXtrx hub in my configuration file and when i add the below I do see my motion sensor.
binary_sensor :
platform: rfxtrx
automatic_add: True
the issue i have is i now what to rename it and then add the 5 second off delay as its a motion sensor so only sends an on signal.
in Hassio i can change the name and device type under the configuration section and this works. but cannot get the delay to work. I have tried to add the below into the configuration.yaml file but when i restart the pi and home assistant it then does not show the sensor at all.
binary_sensor:
platform: rfxtrx
automatic_add: True
devices:
091300006ca2c6001080:
device_class: motion
off_delay:
seconds: 5
Does anyone have any advice on this. I have also tried to put this in the customization.yaml but again nothing.
Any advice would be great as i am running out of things to try.
