[rfxtrx] signal of Selectplus Chime stops rfxtrx from working
When my doorbell rings (a select plus black model) rfxtrx stops receiving anything after that.
With the receive.py example the signal is decoded as followed:
Recv: 0x07 0x16 0x02 0x04 0x00 0xb4 0xc2 0x70 <class 'RFXtrx.SensorEvent'> device=[<class 'RFXtrx.RFXtrxDevice'> type='Select Plus' id='00:b4'] values=[('Battery numeric', 0), ('Rssi numeric', 7), ('Sound', 194)] {'79:0e': <RFXtrx.RFXtrxDevice object at 0xb699b7b0>, '00:b4': <RFXtrx.RFXtrxDevice object at 0xb69b7450>, '31:03': <RFXtrx.RFXtrxDevice object at 0xb69b7490>} {'79:0e': <RFXtrx.RFXtrxDevice object at 0xb699b7b0>, '00:b4': <RFXtrx.RFXtrxDevice object at 0xb69b7450>, '31:03': <RFXtrx.RFXtrxDevice object at 0xb69b7490>} {'79:0e': <RFXtrx.RFXtrxDevice object at 0xb699b7b0>, '00:b4': <RFXtrx.RFXtrxDevice object at 0xb69b7450>, '31:03': <RFXtrx.RFXtrxDevice object at 0xb69b7490>}
the Home-Assistant log file says following, but the sensor is not created:
16-07-03 16:37:32 homeassistant.components.rfxtrx: Receive RFXCOM event from <class 'RFXtrx.RFXtrxDevice'> type='Select Plus' id='00:b4' 16-07-03 16:37:32 homeassistant.components.sensor.rfxtrx: Automatic add rfxtrx.sensor: sensor_00b4
Is this a bug of some kind?
Did you manage to solve the problem yet? I also have 2 SelectPlus doorbell and was wondering if you have a solution to this issue.
i switched to a KAKU doorbell.
i never got the select plus working without issue (rfxtrx received different ID’s for the same button etc).
This pull request should add better support for such devices:
https://github.com/home-assistant/home-assistant/pull/4218
how did you get the RF code for this doorbell ? I have one too, but it seems that each time I press the button, I find a different code, and one press of the button returns multiple codes. I have a SelectPlus white chime, and the code I use to get the RF signals is
https://raw.githubusercontent.com/milaq/rpi-rf/master/scripts/rpi-rf_receive
I’ve recently moved my rfxcom from my Vera to my HA setup, and have been playing around with my sensors. I discovered by doorbell also appears in HA when its pressed, listed as a SelectPlus, but I am also suffering from the ID changing everytime its used, so I have lots of sensors appearing.
I also have hundreds of other rfx sensors appearing with the state as Panic - which I presume are from a neighbour - and I wonder if that is the same problem (ie. just one or two sensors but with changing IDs).
Is there anything I can do to stop the IDs from changing (I assume not, if its coming from the sensor side)?
i’m not sure, but i think this has to do with the way this protocol is handled in pyrfxtrx ?
when i used the fxcom in combination with domoticz the selectplus chime was useable and i could even emit a select plus signal …
Thanks for the reply koen - I’m still playing around with things and not sure how it all works at the moment - its not a problem for me, the door bell was just a nice to have, not a necessity. I’ll update if I ever come to any solution!
Incase anybody with a Old Mr. safe Doorbell “Mr. safe deurbel” ever comes to the message then I have found my doorbel sents out a 433Mhz message (captured with RFLink) with the following code:
2023-12-06 12:44:51.779 DEBUG (MainThread) [rflink.protocol] decoded packet: {'node': 'gateway', 'protocol': 'selectplus', 'id': '01a8', 'switch': '01', 'command': 'on', 'doorbell_melody': 1}selectplus_01a8_01
2023-12-06 12:44:51.780 DEBUG (MainThread) [rflink.protocol] got event: {'id': '', 'command': 'on', 'doorbell_melody': 1}
2023-12-06 12:44:51.780 DEBUG (MainThread) [homeassistant.components.rflink] event of type command: {'id': 'selectplus_01a8_01', 'command': 'on', 'doorbell_melody': 1}
2023-12-06 12:44:51.780 DEBUG (MainThread) [homeassistant.components.rflink] entity_ids: []
2023-12-06 12:44:51.780 DEBUG (MainThread) [homeassistant.components.rflink] device_id not known, adding new device
In the HA config I created a switch with this code and use it to sent a chime message to google speakers around the house. This switch is used in that automation that rings the speakers and I reset the switch after that.
