Rfxtrx Weather Station Problems
Hi Everybody,
i have a problem with my Weather Station from Auriol. I found it with the automatic_add: true command in Rfxtrx sensors. Everything fine. I insert it in my configuration.yaml as follows:
- platform: rfxtrx
    automatic_add: True
    devices:
      10560700a90100e10004000c031c040069:
        fire_event: True
        data_type:
         - Humidity
         - Temperature
So far, so good. It displays the correct temperature and humidity and after 1 Minute it switches all sensor data to zero. This lasts 1 Minute than it displays the correct sensor data. After 1 Minute it shows Zero data and so on and on and on…
Can someone reproduce this error in HA? Is it a problem with Rfxtrx or with the frontend?
For any help thx in advance :slight_smile:
Peter
Hi There
Did you resolve this? I have just picked one up from my local Lidl and if they work well will get a few more
