RGBW in XKNX
Hello, I was able to make normal knx configuration working like this
knx:
  light:
    - name: "rgbwtest"
      address: "1/0/9"
      individual_colors:
          red:
            brightness_address: "2/0/5"
          blue:
            brightness_address: "2/0/6"
          green:
            brightness_address: "2/0/7"
          white:
            brightness_address: "2/0/8"
BUT… my normal config is in XKNX format.
my xknx.yaml does not render a RGB wheel if i address the individual groups with the syntax in https://xknx.io/light.html but only a generic on off switch that does nothing.
Anyone has got any clue?
Or… Is possible to do a hybrid knx + xknx config?
my xknx.yaml:
general:
    own_address: "15.15.249"
groups:
    light:
        DimmerRGBW:
            group_address_brightness_red: 2/0/5
            group_address_brightness_green: 2/0/6
            group_address_brightness_blue: 2/0/7
            group_address_brightness_white: 2/0/8
xknx.yaml and config_file: is deprecated and will be removed next version.
You can use https://xknx.io/config-converter/ to convert to HA yaml Schema.
thanks!!!
i have this kind of problem:
to turn the lights OFF i have to send a 0 brightness value to the knx groups for each of RGBW
because there is no switch on/off groups in the knx device i am using, i just need to send a 0 value
White is sending 0 as brightness and it works, but the minimum brightness for the other three channels (RGB) in hassio seems to be 1.
If i do something like this using a dummy knx group address for “off switch”:
automation :
    - platform: state
      entity_id:
      - light.dmx
      to: "off"
    - service: persistent_notification.create
       message: 'start dmx off'
    - service: light.turn_on
        entity_id:
        - light.dmx
        white_value: 0
        rgb_color:
          - 0
          - 0
          - 0
        brightness: 0
       message: 'end dmx off'
the rgb channels are still on… has anyone got a clue on how to send a 0 in rgb channels in hassio?
    - name: "dmx"
      address: "1/0/9"
      individual_colors:
          red:
          blue:
          green:
          white:
You can use the knx.send service from your automation to send the value directly.
What kind of device is this? It’s very untypical for a knx device not having a 1bit on/off communication object.
it’s a KNX to DMX gateway.
I can map every DMX channel as it was a dimmer and it works fine, but to turn off the DMX channel i have to send a zero
Thanks for the knx.send hint, i will look into this immediately
doing like this seems to work, but i fear for my mental health (i have to do hundreds of these)
However: thanks!!
automation 2:
    - platform: state
      entity_id:
      - light.dmx
      to: "off"
    - service: knx.send
        address: 2/0/5
        payload: [0]
    - service: knx.send
        address: 2/0/6
        payload: [0]
    - service: knx.send
        address: 2/0/7
        payload: [0]
    - service: knx.send
        address: 2/0/8
        payload: [0]
Not sure if you will be very happy with this. The knx light device relies on the “address” you set up as dummy GA for it’s on/off state - that’s why it is required in config.
Maybe using a template light with knx.send and knx_event is a better way with your special setup.
You can send to multiple GAs like this:
- service: knx.send
    address:
      - 2/0/8
      - 2/0/9
    payload:
      - 0
And if your GA structure allows, maybe you could even use templates to have one automation trigger all light entities depending on eg. the dummy address.
thanks Matthias!
It will require some changes to the HA integration too - mostly the Schema and unique_id.
I’m curious, what kind of project is this?
This is now merged to current dev. Will be useable in 2021.6
