Hi! I have done few test setups with Fibaro relays and Fibaro RGBW controller. What I want to achieve is led strip integrated in to roof and 230V wall switch or automation to turn it on. So wall switch can’t turn the RGB controller off.
Basic Fibaro relay with push-button style switch works perfectly for anything else, but if I use RGB controller after the relay it cuts the power and automations don’t work anymore. Also controller connecting back to Z-Wave network tooks way too much time.
Fibaro RGBW controller was pretty close to be good but if doesn’t work properly with the switch if automation changes the color.
What options I have? Is there some configurations on Fibaro controller? Or some nice Z-Wave controller with built-in relay? I can run the wires how ever want so battery powered switches are not options.
