Rhasspy + Logitech Media Server: Conflict?
Setting a new Raspberry 3 to host Rhasspy and LMS bring me to a strange issue:
  • First attempt
    Starting with a clean Raspbian image, I’ve installed Rhasspy as per instruction and it was working flawless.
    Then I’ve installed LMS and squeezelight client cause I need to use the raspberry in a multiroom audio system via airplay.
    After LMS installation Rhasspy stopped working and the whole system became sluggish and unresponsive.
  • Second attempt:
    Started from scratch I proceeded backwards.
    I’ve installed LMS and client, then Rhasspy and as soon as I’ve set which card to use (Rhasspy settings) again the system became unresponsive, LMS and Rhasspy didn’t work anymore and speakers started to buzz.
    Stopping Rhasspy docker image seems to solve the issue.
Things to note:
I’ve disabled the onboard audio card and I’m using a Respeaker 2 hat.
The issue seems to start when in Rhasspy settings I try to change from default card (for record and play) to Respeaker.
But having disabled the onboard card default card and Respeaker card are the same.
I’ve no idea what to try… Any hint is really appreciated
