EDIT 9/30/2023 -
All development has been consolidated here
EDIT 7/18/2023 -
Econet heat pump water heaters are fully supported by the component.
HVAC, we have full control of the thermostat and access to a lot of diagnostic data that will make its way into sensors soon.
EDIT 5/14/2023 -
If anyone is interested. We have had a lot of success so far in decoding the protocol.
With water heaters we have been able to set temperatures and change modes with an rs485 connection including reading various sensors and pulling it into home assistant.
It would be great to get more people involved especially those with econet HVAC systems as I am currently the only one.
To join the discussion please join the discord channel.
Recommended hardware.
https://www.digikey.com/en/products/detail/m5stack-technology-co-ltd/K045/14318599
Recommended cable.
https://www.digikey.com/en/products/detail/assmann-wsw-components/AT-S-26-6-4-S-7-OE/1972674
Here’s something that can get you started with esphome yaml and a custom component made by @stockmopar on discord.
Another potentially easier yaml to setup to get started with getting logs.
Original Post 09/2022 -
Currently, there’s no local integration for Rheem econet.
However it is possible to control Rheem econet devices locally. I have done a bunch of research and found documentation on the climate talk protocol (Rheem was apart of this), and some methods of listening to rs485 Traffic and potentially controlling devices through climate talk.
Reverse engineering the protocol is way out of my league. I’m hoping someone this will be helpful for someone who’s interested in locally controlling their econet devices and has the skills to do reverse engineer the protocol but needed a starting point and testers.
I’m willing to test and pull logs. Just need to know what to do. I have a Rheem econet thermostat (heat pump) and an econet electric hot water heater.
Research Findings:
Climate Talk Specification -
Climate Talk Read/Control -
Rs485 Listener -
Openhab Climatetalk discussion (logs were posted here) -
HVAC - ClimateTalk Protocol - Home Automation - openHAB Community[quote=“Danny2100, post:1, topic:465301, full:true”]
EDIT 5/14/2023 -
Recommended cable.
Research Findings:
Rs485 Listener -
[/quote]
